Question about Lexmark T640 Laser Printer
917.00 service trasfer roller - Lexmark T640 Laser Printer
    President:
  • 2,306 Answers
That transfer roller is available at www.precisionroller.com for $39.95
Posted on Sep 25, 2009
Trasfer switch dos not trasfer
What transfer switch make and model? There are many OEMS amd they all operate electronically differently, with respect to controls and how the utility and generator power is sensed. Let us know and we can maybe help. Renee Fuller advanced-power-technologies.com
Nov 14, 2013 | Electrical Supplies
I want to be able to trasfere money and pay my bills through internet? How can i apply
Start with your bank. Ask them whether they have an internet banking service available.
Aug 01, 2013 | Computers & Internet
Can't register camera to trasfer photos to computer
Go online to camera maker's website and download the driver needed. This will help you transfer photos.
Feb 29, 2012 | PhoTags
I have an hp2430, it is pringinting shadows along the left edge of the papers and a line along the right side. I have printed a cleaning page 3 times and replaced the cartridge, running the cleaning page...
the line could be caused by a scratched DRUM unit or a contaminated trasfer roller... And the shadow is probably a broken MICA ROLLER in the FUSER,
To get rid of the line (if the drum is OK) you need a mantenance KIT for that model, (pickup roller, transfer roller, separating pads etc...), for the shadow you need a new FUSER
Cheers!
Mar 22, 2011 | HP LaserJet 2420 Printer
Grinding noise coming out of rear trasfer case were u joint. is there a bearing in front of the trasfer case that can go bad?
Need better info lots of parts in between rear transfer case also has axles in the cases
Nov 12, 2010 | 2004 Dodge Ram 1500
Ricoh ap3800c, I am getting a series of paper jams, they are type A. Ie they occur in the transfer belt area and partially exit inside the side compartment. I have changed the paper to a heavier type, I...
try to clean the paper feed rollers, if this return call the technician to check the paper feed clutches. i think the secondary feed clutch is loosing the grip to transfer the paper up to the fixing unit.
Sep 06, 2010 | Ricoh Office Equipment & Supplies
What does this error message mean: "917.00 service transfer roll"
The transfer roller is missing, not touching the drum, poor contact to the transfer high voltage or transfer high voltage shorted.
The trasfer roller is below the drum. Its bearings are on springs to press the paper against the drum. The drum rotates it by gears at one end. One of the bearings have electrical contact with the spring and the spring is connected to the DC controller. The transfer roller receives high voltage that attracts the toner from the drum. It's current is measured and when it's not within specifications the error occures.
Aug 05, 2010 | Dell 5210n Laser Printer
. i want trasfer my videos to pc
You can easily transfer your video clips to PC by connecting the camcorder shown in the picture above. For more detailed information please download the user manual from link below.
http://service.us.panasonic.com/OPERMANPDF/PVDV103.PDF
Mar 21, 2010 | Video Cameras
Gestetner 2722z copier, new drum, new transfer belt, smudges yet
The image is not transferring properly..........
remove and clean all corona wires (thin wires that create the latent image) use a q tip and dip in rubbing alcoholhot
Also make sure the fuser rollers are hot(insert or trick safety switches to determine if the fuser lamps are lighting usually upper and lower
Also check the imaging lamp to be sure it does not have any dark burn marks on it and clean the mirrors and the glass under the coy area
Dec 30, 2008 | Gestetner Office Equipment & Supplies
DP-190 Blank Copies
By the write unit i guess you mean the LSU. If you've already ruled out the the image drum and transfer roller you're only left with a few possibilities. I'm also guessing this fault only happened after you replaced the LSU??
1 is there something obstructing the beam from the scanner to the image drum.
2 have you damaged one of the 2 harnesses going into the LSU (check the contiuity) also check the connections on the system board.
3 The high voltage power supply may be faulty.
4 The system board may be faulty.
I repair lots of the DP180's the european version
Aug 24, 2008 | Panasonic DP190 All-In-One Laser Printer
Lexmark T640 Laser Printer Logo
322 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
