Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I have connected up all leads , cartridges and instalation as per manual. the printer turns on but will not get the paper moving.
  • 101 Answers
Hello
here are the steps.
1. Remove the paper from the paper tray.
2. Fan the stack of pape
3. Open and fully extend the paper tray.
4.Load paper into the paper tray.
5.Align the paper with the dotted alignment lines on the paper tray, then adjust the paper guides until they lightly touch the paper.
If issue persists,
1.Disconnect the following from the back of your printer:
* AC power cord
* USB cable
3.Remove the paper from the paper tray.
4.Remove foreign objects or debris from the paper tray. 5.You may need a flashlight to view the back of the tray.
6.Open the access cover for the printer
7.Remove foreign objects or debris from the paper path. 8.You may need a flashlight to view the paper path.
9.Remove the cleanout assembly from the rear cleanout area:
a.Gently press and hold the tab on the left side of the cleanout assembly.
b. Carefully pivot the left side of the cleanout assembly toward you to remove it.
10.Lightly moisten a lint-free cloth with water, then gently clean the surface of the feed rollers. Advance the feed rollers with your thumb, and continue cleaning.
11.Allow the feed rollers are completely dry.
12. Install the cleanout assembly.
a.Insert the right side of the cleanout assembly - 1 into the back of the printer so that the tabs - 2 fit into the slots on the right side of the cleanout area.
b.Rotate the left side of the cleanout assembly until the latch - 3 snaps into place.
c.Pull on the cleanout assembly to insure that it is seated.
13.Connect the following to the back of your printer:
* AC power cord
* USB cable
14.Wait 30 seconds, then turn on your printer.
15.Pull the paper tray all the way out until the paper 16.Squeeze and move the paper-width guide to the left.
17.Fan the stack of paper and load it into the paper tray.
18.Squeeze and move the paper-width guide to the right until it touches the stack of paper.
19.Lift the small gray paper stop until it is perpendicular to the paper tray.
20. Make a print
If issue persists, the printer itself needs to be replaced. Call 1.800.421.6699
Thanks
Posted on Sep 25, 2009
Epson printer xp 305 printer error E-01
This Epson Printer error E-01 occurs in the Epson Service Manual which indicates a type of fatal error. It simply signifies that the printer is incapable to finish the self-test process. When users are trying to power ON the printer it begins to check for all systems. If it is found that it is unable to finish the self test process then, the printer will come up with an error message as mentioned above. Follow these steps to resolve Error E-01.
Steps to Resolve Error E-01:
Step 1: Turn on/off the printer power button
  • Turn the power off. Wait for a while then turn on it again.
Step 2: Managing the lock of the printer
  • Store transportation lock carefully.
Step 3: Managing the CD tray
  • Press the CD Tray button to retract the tray to its original storage position. Be careful never to push or pull the CD tray into the wrong position. Turn off the Epson Printer and make sure that there is no paper left which may lead to paper jam issue inside the unit.
Step 4: Checking the printer cartridge
  • If the printer is installed with the CISS then, make sure that its carriage is easily movable towards left and right side.
  • The printer's upper scanner part should be closed tightly.
Step 5: Perform a check-up process.
  • Install original Epson ink cartridges and then run the printer.
Step 6: Access the cartridge
  • Access the cartridge loading area while the printer is in off-mode and then, move the carriage right away from the stop. Carefully disassemble the printer and then, clean all its optical sensors, paper feed sensors, encoder strip as well as disc encoder.
Contact Epson Printer Support Number if you have any issues in printer.
Apr 12, 2014 | Epson Stylus RX580 InkJet Photo Printer
Paper will not feed through
Usually its on the rollers
Turn off first your printer
move teh cartridge carrier manually with your hands
. remove all the cartridges
- clean the rollers with a damp cloth make sure you moved the rollers while you are cleaning
move the cartridge carrier manually frm left to right 5x
Once your done return the cartridge close it properly
then try to power it on
In case nothing happens
remove all the parts on the computer remove the cartridges paper , black box
lift the printer up turn it upside down make sure the cover is open so that any foreign materail will fall
THen shake it for 5x
hope it help
May 23, 2011 | Lexmark X2600 InkJet Printer
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
I have an HP D4300 printer/scanner and I can't figure out how to open a in order to change cartridges. Please advise.
Installation instructions
Always install the tri-color print cartridge in the left side of the print cartridge carriage.
Install the black or photo print cartridge in the right side of the print cartridge carriage.
To replace a print cartridge
1. Verify that the printer is turned on.
2. Load Letter or A4 plain, white paper in the paper tray.
3. Open the printer cover.
Chapter 10
64 Maintenance Maintenance
4. Wait until the print cartridge carriage moves to the right side of the printer and is idle
and quiet.
5. Press down on the print cartridge, and then slide it out of the print cartridge carriage.
6. Remove the replacement print cartridge from its packaging and carefully remove the
plastic tape. Hold the print cartridge so that the copper strips are on the bottom and
facing toward the printer.
1 Remove plastic tape
CAUTION: Do not touch the print cartridge ink nozzles or copper contacts.
Touching these parts will result in clogs, ink failure, and bad electrical connections.
Do not remove the copper strips. They are required electrical contacts.
Install print cartridges 65
Maintenance
7. Slide the print cartridge at a slight upward angle into the carriage until the cartridge
snaps into place.
8. Close the printer cover.
Align print cartridges for optimum print quality.
For information about storing print cartridges, see Maintain print cartridges.
For information about recycling empty print cartridges, see HP inkjet supplies recycling
program.
WARNING! Keep both new and used print cartridges out of the reach of children.
Download manual for proper guidance. http://h10032.www1.hp.com/ctg/Manual/c01438085.pdf
I hope this works for you. Goodluck!
Mongkey
"Understanding explains better..."
Jan 22, 2011 | HP Office Equipment & Supplies
My printer is not set up to print yet what do I do
Setting up the All-in-One Follow these steps in order. When you are finished, you can click the appropriate link at the end of this document if you need instructions to install the product software. CAUTION: Do NOT connect the USB cable now. You need a USB cable to connect the product to the computer, but you will be prompted to connect it at the correct time during software installation. Step one: Unpack the All-in-One
  1. Lower the paper tray and remove all packing material. Figure 1: Lower the paper tray
  2. Lower thecartridge door and remove all packing material.
Step two: Check the contents of the box The contents might vary by country/region. See the packaging for a list of items shipped in the box. Step three: Connect the power cord and adapter Connect the power cord and adapter. Step four: Turn on the power
  1. Press the On button
  2. Wait 30 seconds for the product to start up.
Step five: Load plain paper
  1. Pull out the tray extender.
  2. Load plain white paper.
  3. Figure 6: Load plain white paper
Step six: Install the cartridges
  1. Open the cartridge door. Make sure the carriage moves to the center. If it does not move to the center, turn the product off and then turn it on again. NOTE: The product must be turned on to insert cartridges. Open the cartridge door
  2. Remove the tape from both cartridges. CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 9: Copper-colored contacts
  3. Hold the cartridges with the HP logo on top.
  4. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Make sure to push the cartridges in firmly until they snap into place.
  5. Push the cartridge in firmly
  6. Close the cartridge door
Step seven: Align the cartridges Make sure that paper is loaded in the tray, and then wait a few minutes while the cartridge alignment page prints. After the alignment page prints, place it face-down on the glass and close the lid. Press the Scan button to complete the alignment. Wait until the green On light stops blinking. to see full diagrams please follow the link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00853006&cc=ca&lc=en&dlc=en&product=3177566
Jun 28, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
The printer requires attention. Try the following:
● If the printer is connected to a computer, check the computer screen for
instructions. If the printer is not connected to a computer, check for the following
problems:
– Top cover open
– Out of paper
– Paper jam
– Print carriage jammed or stuck
– Print cartridge inserted incorrectly
– Incorrect print cartridge installed
● If you are unable to solve the problem by using the instructions above, turn off the
printer and unplug the printer's power cord. Wait one minute, then plug it in again.
Turn on the printer.
Sep 29, 2009 | HP Photosmart 7450 InkJet Printer
5100 ERROR
As per the manual...
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
Mar 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP150
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer:
CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
turn the printer off and lift  the front top and move the cartridge carriage manually at the center and then on the printer.
Mar 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
6A00 Service Error
Had this error and did the following to solve the problem.
Turn the printer off.
Open the top cover and move the printer cartridge to the left.
On the right you can see a white part.
Press it down.
Turn the printer on.
Sep 15, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
117 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
