Question about Xenon Computers & Internet
Can't locate the power button to turn the thing on
    Problem Solver:
  • 11 Answers
You need to buy a 4-Pin power connector.
Posted on Oct 03, 2009
Blue screen, no picture. What's wrong?
The board where the power button is located (same board for the other buttons too) is probably bad. It's all one board, which tells the power board to come on. If this happened after a power surge, and you're not using a surge protector, multiple boards can be bad. (You can't just plug these fragile TV and Blu-Ray players into the wall outlet. Eventually a surge will destroy them). Ps... A lot of people are suddenly making this same complaint with Vizio TV's.
Mar 03, 2016 | Vizio Televison & Video
WS-55907
1)Pull chassis or center PC board
2)Replace STK392-570 IC's
3)Locate green soldered-in pico fuses = use ohm meter
to find which ones are open ( bad ) = replace
4)Reassemble, test
Nov 19, 2007 | Mitsubishi WS-55907 55" Rear Projection...
Turn on data and location without unlocking screen
Ohhh. That sucks... Looks like you have run into the largest problem you could have. That's why I have never liked the idea of fingerprint scanners to unlock a phone. The only thing I can tell you to do is to hard reset your phone. Try turning it off and then hold down the power and volume-up (or mabey volume-down) buttons and try to boot it to EFIES mode. Follow the steps to reset by using your volume up/down and power button. That's all I know you can do without it being connected to the internet. If I misunderstood your question or you need more assistance, just let me know!
-Mr. W
Sep 16, 2014 | Samsung Galaxy S5
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
When you push the main power button on and the standby button it turns green for 2 seconds then turns right back to red what's going on???
1 or 2 things, Blowed Fuse on the Deflection power supply board
6.3 amps will be located in the Middle of chassis.
STK ICs need to be replaced STK392-110 use 120s
Mats Electronics has them 1-800-628-1118
Oct 31, 2010 | Pioneer PRO-700HD 64" Rear Projection...
I got the code C:31:22 flashing on the screen. what should i do?
this error pertains to one of the reels (the thing that turns the tape)is malfunctioning.so most likely you'll be having issues w/recording,playing,fast forwarding or rewinding the tape.you can try RESET (press the reset button located inside and beside the eject button in the tape compartment cover, while cam is on).if it doesn't work try POWER RESET (turn cam off,remove the batt,make sure the ac adaptor is not connected.turn power switch to camera or player, and leave w/o power for at least a minute.turn power switch back to off and reinsert batt.check if working).if still you get the error,repair might be needed.hope this helps.thanks:)
Apr 06, 2010 | Sony Handycam CCD-TRV608 Camcorder
My shutter is broken on my Kodak V610
I'm afraid your camera needs a repair. There's no other way. Contact Kodak under 1-800-421-6699.
Mar 10, 2010 | Kodak EasyShare V610 Digital Camera
TV won't turn on...after hitting the power button, the light turn green for about 3 seconds, then turns red and the screen never come on. Pressing the power button again turns the whole thing off (no...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | NEC PlasmaSync 42MP2 42 in. Television
Remotes won't turn on
ok,you changed the battery already but did you synchronize the remote to the console?beside the battery of the remote is a small red button.did you try to press this button? as well as the red button on the console?it is located on the memory card port of the wii.try it first,let me know
Dec 25, 2008 | Nintendo Wii Console
Sony like no other,
If you find the user manual for the Webcam U you will be able to locate the Power Button to the Web cam.
Connect it to the computer,
then Press the Power button,Verify if the camera is receiving the Power by Double checking the lights.
if every thing works then install the software & drivers needed and you are ready to go... :)
May 11, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
Top Xenon Computers & Internet Experts
David Payne
David Payne
Are you a Xenon Computer and Internet Expert? Answer questions, earn points and help others
