Question about Fuji FinePix F700 Digital Camera
NO COLOR IN PICTURES - Fuji FinePix F700 Digital Camera
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Apr 13, 2010 | Televison & Video
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Color picture jumps in and out of normal color mode . . .
You have bad solder connection in or around the Jungle IC and or color processing Circuits. Most commonly the area is the color cyrstal, located on the main board.
Oct 10, 2009 | Televison & Video
YThe colors in my picture have yellow/green color cast.
When you take pictures under certain artificial lighting conditions- such as fluorescent, incandescent, or halogen lighting, the colors in your image may take on a yellow or green cast. You can use HotShots to touch-up the colors; see Chapter 7 for instructions.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Fuji FinePix F700 Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
