Question about Viking Dishwashers
Eaton viking i have an old eaton viking dishwasher. model# DC392W149 the seal in the pump for diverting water to the top spinner bar is worn out. i cannot seem to find parts anywhere. should i try to find a new pump assembly or break down and buy a new dishwasher?
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: eaton viking dishwasher
it may not be the pump.if it leaks when you run a wash cycle then the pump seal may be bad but if it only leaks when you drain it,it seems that its a drain hose/piping connection.
Posted on Nov 04, 2007
  • 117 Answers
SOURCE: Whirlpool dishwasher float 'assembly' model-DU810SWPQ2
Enter your model number into a site like partselect.com to get a parts diagram for your dishwasher so that you can see what the part looks like. The float just extends through the base to close a micro switch so the dishwasher shuts off the inlet water valve.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
  • 423 Answers
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
  • 3 Answers
SOURCE: the top water spinner arm fell off, how to get it
This just happened to me. The spinner arm fell off. It left behind two pieces of plastic attached to the roof of the machine: a grey sunburst shape, and within that, a white circle with two prongs. It looks like the spinner arm should snap onto the white circle with prongs . . . but you can't just press it back on, because there is no resistance on the other side and the white circle just becomes displaced instead of snapping together.
But the good news is that the grey sunburst screws on and off! Unscrew it until it comes free from the roof of your machine. Now snap the white circle and the spinner arm together, with the grey sunburst between them. Give it a test spin to make sure it's all together and working, and then screw the whole assembly back onto the roof of your dishwasher.
Apologies for the lack of pictures . . . this must sound crazy to anyone who's not looking at what I'm looking at--but it worked!
Posted on Nov 03, 2010
I have found an old boat engine with no make and no cover for it made in Canada patented in Canada in 1956, 57, 58, 60 serial number is C384919 and model number 25DE21V or could be 2IV who made it
Eaton's Viking
[PDF]Eaton's V Eaton's Viking Outboards Model Y iking Outboards Model Y ... www.romeosmarine.com/images/Outboards/VikingModel-YearGuide-2007edition.pdf
  1. Cached
  2. Similar
Eaton's Viking Outboards Model Y iking Outboards Model Y iking Outboards Model Year Guide ear Guide ... 25DE21V 25.0 Electric Starting. 40D15V 40.0 ...
[PDF]Eaton's Viking Outboards Model Year Guide ... - Richard L. Paquette
https://richardlpaquette.ca/VikingModel-YearGuide.pdf
  1. Cached
Eaton's Viking Outboards Model Year Guide. 1933-1969. Richard L. Paquette, Third Edition, August 2009. Year: 1933-35. 1936-38. 1939. 1939-41. 1940-41.
Original 1963 Eatons Viking 25 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking. 25 HP. Outboard Motor. Parts List. Model 25D21V. &. 25DE21V. NOS. (Sellers Inventory no. B111003). Up for sale, we are ...
Original 1963 Eatons Viking 3 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking 3 HP. Outboard Motor. Parts List. Model 3D19V. NOS. (Sellers Inventory no. B111000). Up for sale, we are offering an original ...
Original 1963 Eaton's Viking 5 HP Outboard Motor Parts Catalog Model
  1. Cached
Original. 1963. Eaton's Viking. 5 HP. Outboard Motor Parts List. Model 5D22V. NOS. (Sellers Inventory no. B111001). Up for sale, we are offering an original ... Eaton Viking 25DE21V Google Search
Sep 21, 2017 | Boating
Eaton viking dryer
The drum rollers may be worn. They are a common failure item.
Oct 31, 2017 | Dryers
Top spinner not spinning
This is most likely because the seal for the top spray bar is bad/missing or has debris in it or in the pump.
May 21, 2013 | Siemens 24 in. SE64A630GB Built-In...
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
Water isn't flowing in through the spinners in the dishwasher.
Look at the end of the wash and no water in the bottom, it is OK. The water is pumped out through the pump. Hence you would have found the water mid way. Pump will start after the wash cycle is fully finished it's function or as per the float level!
May 31, 2010 | Viking 24 in. Professional Series VUD141...
Dishes on top rack don't get washed. Water
replace the wter conduit that runs up to the top and center spinner arms,after while these plastic conduit outlets get worn by water going thru them and leak past the o-rings installed on them
Apr 15, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Middle and top spinners do not spin The pump is pushing water up the back delivery tube. There are no dishes in the unit and I was able to trick the door into thinking it was closed so I could watch what...
Remove each spray arm and check it is clear of food particlesat the jets. The next problem may occour at the rotating joint . If the seal is not good, you can loose a lot of water out of this point.. If both of these seem reasonable, then yes the circulation pump may need checking. First check for any debris in the impeller, and that it is not worn or damaged, and that it is attached to the motor or the coupling is still good. If these are ok, then the motors='s capacitor may be faulty - causing it to buzz more than normal usually, and it looses efficiency, getting hot in the process.
One of these should solve the problem !
Aug 05, 2009 | Dishwashers
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Eaton viking dishwasher
Nov 03, 2007 | Dishwashers
Dishwashers Logo
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
