Question about Intel Microstar MS-6526 Pentium 4 ATX Motherboard w/ Video - MS-6526
NEED TO CHANGE MY BIOS SO MY NEW GRAPHICS CARD WILL LOAD INSTEAD OF THE ONBOARD ONE BUT I DONT KNOW WHICH SETTING TO CHANG
    President:
  • 942 Answers
Hello
In that way no need to change the BIOS settings, you can install a new graphics card directly. Once you are already installed the new graphics card you need to install also the driver so that it will work properly. Connect your monitor cord to the new installed graphics card. Now you can enjoy using your computer with the new installed graphics card.
Regards
PCmania
Posted on Sep 26, 2009
Pavillion a6700y desktop onboard graphics out
you have to change the gfx setting in the bios from onboard to pci.
push delete button when the pc starts intil your are in the bios.
there you find the section with internal elements and find gfx or grafik. change it to pci
Oct 02, 2013 | HP Pavilion a6700y PC Desktop
How to disabled vga onboard motherboard 865g m8r
There are lots of different Bios's out there and all are different so I cannot give specific instruction. You need to restart your machine and on boot up you will see a screen that has options like (F2) Settings (ESC) Boot menu things like that. They vary by brand but you need to watch for what you need to press to enter your settings that will take you into your Bios If your not fast enough on the first reboot try again until you get into your bios once in your bios you will be looking for a setting that has something to do with your display ie: onboard VGA your bios may not have the option to disable your onboard but instead give you the option to enable a PCI-E Graphics Card as your first display. Keep in mind that if you do not know what a setting does Don't Change it. You can cause major system problems by changing settings that need not be changed. direction for navigation through your bios should be listed at the top or bottom of the bios screen. Be sure to save your new setting when you leave your bios.
Feb 21, 2011 | Computers & Internet
Disable onboard graphics of my PCChips M825LU motherboard?
Yes its a BIOS setting that you have to change. Usually you change from on-board to AGP settings or plug the graphics card in, take out the motherboard battery and the power cord from the back, leave it for 20 minutes and put them all back again.
This will reset the BIOS and should auto detect the AGP graphics card. You will however need to set the date and time but you can do that from Windows.
Regards.
Jun 28, 2010 | PC Chips Computers & Internet
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP-95&fMTYPE=LGA775
Cheers!
Mike
Nov 12, 2009 | Abit IP-95 Motherboard
Monitor goes black after windows boots up
Try removing the video card, and look up your motherboard / system manual on dell's website on how to manually reset the bios.
1. Remove video card
2. Reset BIOS (physically opening the computer and using a special jumper and/or removing the battery...what ever the manufacturer says to do to reset the BIOS).
3. After BIOS is reset, try booting up via your onboard video card first. Once you get that working, go into the bios settings and make sure it is set to boot the onboard only for right now and then you can make sure the ATI software is fully uninstalled when you get into windows.
4. Reinstall the ATI card and boot up with the video still connected to the onboard card. See if it will let you install the driver.
The trick here is to reset the bios and get the system booting off the onboard card if at all possible. If that works, then you can always reinstall drivers and then tweak the bios to boot off the AGP card instead of the onboard.
May 01, 2009 | Rosewill RADEON 9200LE (128 MB) Graphic...
Monitor stays black until boot up to Desktop
you use a graphics card as your main output?
and you have onboard graphics output too that you dont use?
if so then you will have to plug your monitor lead into the onboard output socket to see bios. i think you need to go into bios and change which device starts from boot.
it sounds like you have the onboard graphics as your boot device and windows using the graphics card.
Feb 26, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Graphics card
Hi Harikris, no you can not install just any graphics card. You're Intel D845GLLY board uses an onboard graphics card. (It's an AGP graphics card).
If it's you're intention to install a new graphics card you must use a PCI graphics card. (Understand that the AGP onboard graphics is faster than a PCI graphics card). However, the PCI cards do use their own memory. (Which fee’s you're system memory to run windows.
The Intel D845GLLY has 4 PCI (White) slots, onboard. You can add a video card into the system. You're onboard video card does use you're system memory to function. If you're PC has 512MB of system memory & you're video card is set to use 128MB of memory. Than you're system is left to run with 128MB. One would think you're system is running a little slow.
The Intel D845GLLY motherboard can use up to 256MB of system memory. You can set the amount of system memory in the bios as shown on page 49, table 18. In you're manual. If you do not have you're manual you can download it from here: http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
May I suggest you increase you're system memory to 1GB. Than increase you're graphics memory to 256MB. You're system will run faster & so will you're graphics card. These older Intel motherboards require memory current for you're board. Click this link: http://www.memory-up.com/Memory/IntelD12696.html
If you still feel that you want to use the slower PCI graphics card you can choose from any listed on this link: http://www.newegg.com/product/ProductList.aspx?N=2000380048+1069609642&Submit=ENE&SubCategory=48&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-NA-_-NA-_-NA
You will also need to change a setting in you're bios to boot to the PCI card instead of the AGP onboard card. Page 49.
Good Luck!
M
Jun 04, 2008 | Intel D845GLLY Motherboard
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Disabling the onboard graphics for this motherboard
hi, go to system bios, i think in the second options check out for primary display , you will have options for add on, or onboard, change it to add on, or there is also an option to disable the primary display somewhere there, browse the bios around , you will find either of it. let me know
Dec 16, 2007 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
Nov 24, 2007 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
141 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
