Question about Panasonic Lumix DMC-FX33A Digital Camera
When I turn the camera on the zoom lens goes in and out three times and then the message says to turn the camera off and then on again. I do this and it does the same thing. I was taking pictures and it was working just fine. It started to do this for no apparent reason.
    Scholar:
  • 96 Answers
It is a lens issue, will need to go in for servicing. Possible reasons are knock or grit/sand in lens unit. If you have had it to the beach on a windy day try holding it over a piece of white paper with lens down about a foot away from the paper, give it a few taps on the bottom and see if sand/grit comes out. I fixed these camera's for 4 years and 90 percent of the problems were droppage/ sand related. SORRY.
Posted on Sep 27, 2009
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to www.unitedcamera.com
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
The lenses were stuck and on the screen it says "lens error".I do not know how it happened. We were just taking photos and when we are about to view them, it vibrated then turned itself off.
This message appears when the lens performs some unexpected operation.If the same message appears after you turn power back on please check that if there is something which blocks the motorized movement of the lens.If so clean it with cotton swabs or soft cloth.After cleaning power off and on again repeatedly two three times.
Jun 04, 2011 | Casio Exilim Zoom EXZ33 Digital Camera
The camera turns on, the zoom does not go out, then shows message
That message appears any time force has been applied to the lens. You may need service.
Feb 21, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens goes in and out three times when turning on or shutin off.
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is recommended.
Jun 15, 2009 | Sony Cameras
Camera wont zoom it just says turn off
It sounds like you have a damaged zoom servo.. which is odd because you're camera probably extends the lens once it's originally turned on. The motor/servo is kind of expensive to replace and it may be more cost effective to purchase a newer camera.
To make sure i'm correct. try turning your camera on with your hand over the lens to stop it from protruding. if you get a similar or the same message then it's the motor. If it just beeps then i have no idea what the issue is. Has the camera been dropped recently?
Dec 19, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Lens/zoom wont come out
The lens mechanism inside of the lens unit is damaged. The fix is to change the lens. You can send the camera to authorized service rep for an estimate. I believe that the cost of service many be close to or even more expensive than replacing the camera.
Jerry G.
Jul 03, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-FX33A Digital Camera Logo
123 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
