Question about Dell 924 All-in-One InkJet Printer
Carrier jam When I tried to print today, the display on my printer showed, " carrier jam, fix and then press start." I followed the instructions on the dell website which said to remove the power from the printer for 15 secs and then replace it, and that did not work. I was told it was cheaper to buy a new printer than to fix the problem. I can't afford one right now and I NEED my printer to print college assignments. Could anyone help, PLEASE!!!!!!!
  • 298 Answers
SOURCE: cartridge error 50C on Dell printer A940
Were you aware of this Dell Printer A940 Cartridge scam!
Details
If this is not the problem then I would suggest
uninstalling & reinstalling the drivers from the
cd
Posted on Dec 29, 2007
SOURCE: Dell 944 All-in-One Printer - printhead carrier jam
I opened my printer while it was on and turned it off. As the carrier moved over and came into view, I found the problem. it had popped open, so I simply had to close it. Then, my printer worked again.
Posted on Jan 19, 2008
SOURCE: Carrier jam on dell 924 printer??
jmhomulos, your solution certainly put me on the right track, however it was the cartridge on the far left that was the problem on my 944. I used a firm plastic kitchen spatula to hold cartridge top down enabeling both cartridges to engage properly.
I would never have fixed it if not for your help, I did not even know what a carrier was and as far as Dell's solution, well, stupid leading stupider comes to mind.
Thanks from Ireland,
Lilian1.
Posted on Jun 05, 2008
rhoncruz
  • 134 Answers
SOURCE: Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Posted on Dec 02, 2008
  • 2692 Answers
SOURCE: My Dell 946 All in One displays 'Right Cartridge Incorrect'
Install old cartriage, if you still have it, let the machine tell you that it is empty, then go through the install process with one of the new ones.
Posted on Dec 19, 2008
My printer will not print, keeps displaying ( clear carrier jam! ). How can I fix it?? Do I need to buy a new printer or is this an easy fix. I 've unplugged the printer and checked ink cartridges...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Open the top of the printer to make the ink cartridge carrier accessible. Grab the ink cartridge carrier with your hand and slowly move it back and forth until it moves freely. Then plug the printer back in and turn it on. That should solve your issue.
Sep 25, 2011 | Dell V305 All-In-One InkJet Printer
I Got a dell printer and i don't know what to do and in the printer it says Clear Carrier Jam
Turn the printer on.
Lift the lid to expose the print-head mechanism.
The "carrier" is that part of the mechanism that moves the print-head across its range.
Something is physically blocking, or "jamming", that carrier.
Feb 25, 2011 | Dell V305 All-In-One InkJet Printer
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Exclamation point next to on button and will n ot print
Push the print head to its starting position (usually far left) and reset the printer.
Jun 03, 2009 | Dell 924 All-in-One InkJet Printer
Dell926
Clear Carrier JamThese are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges.
Regards
Chittaranjan
Dec 14, 2008 | Dell 926 All-In-One InkJet Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Dell all in one printer 940
try holding the power down for 15 seconds
Mar 06, 2008 | Dell A940 All-In-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
Dell 942 All-In-One InkJet Printer
I have had the clear carrier jam problem the past 3months, spoke to over ten technicians but no one seems to have been able to resolve it, let alone clearly explain the cause. But just to say buy another printer.
How many Dell 942 printer am I going to buy!!!!!?????
Sep 09, 2007 | Dell 942 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
49 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
