Question about Microsoft Windows 98 for PC
I have windows vista on laptop is it compatible with windows 98 games
  • 6,831 Answers
Hello
Something you can try is to ret the compatibillity mode of windows to the saught after os you want it be compatible with. Please rate this.
Best regards
Posted on Sep 25, 2009
  • 855 Answers
Not for most games of the windows 98. Some will run but not the same as they did in 98.
Games
you can try, run in compatibility mode by right clicking the icon and going to properties and choosing compatibility and then choosing which OS
Jun 30, 2012 | HP Computers & Internet
This is a game created for Windows 95/98. How do I run it in Windows Vista?
By default it should work, but some games would need you to change its compatibility. After you install it, right click the shortcut on the desktop and go to properties. After that click the compatibility tab, then check the box for 'Run this program in compatibility mode for:" And pick WIndows 95 or 98.
Feb 25, 2011 | Knowledge Adventure JumpStart 2nd Grade...
I have Spiritual Expressions for Windows 98 but my laptop has Windows Vista. How can I make the program work on Vista?
You may be able to get it to work by installing it in compatability mode. Right click on the install file and choose windows 98 on the compatability tab.
You could also use a virtual machine, you could load a copy of windows 98 and then use your program in the VM.
There are free Virtual machine programs, but you would need a valid copy of win 98
Oct 05, 2010 | Broderbund American Greetings Spiritual...
Is the Logitech Extreme 3D joystick compatible with my Windows Vista?
Yes it is very much compatible with windows vista.
it is compatible with xp,98,vista but not with windows 7
so as you have windows vista,so you can use your joystick
Jul 22, 2010 | Logitech Extreme 3D Pro Joystick
Compatibily of Janes FA-18. After using MS wizard, and setting compatiblity for game profiles, game will still say not compatible and exit play. My system is VISTA. Game takes WINDOWS 98. How can I get the...
Try this Right click on the Icon goto properties then look for tab that says compatibilty. Once there you will see option that says "Run Program in Compatiabilty Mode for" select the list and find windows 98 and make sure the box is checked to , then hit apply. That should run it in win98 mode... Vista kind of sucks for compatible on old stuff they fix it in windows 7. Hope that helps. Also dont forget to rate me .
Thanks
Micheal
Sep 02, 2009 | Dell Computers & Internet
Cant get creatures 2 to work on windows vista
Do you get an error code?
Right-click the creatures setup file or the .exe file that you use to run the game and choose properties.
click on compatibility and change the compatibility to Windows 98/me ,also check the option at the bottom to run as administrator ,click on apply and the OK.
May 06, 2009 | HP Computers & Internet
My game is loaded but when i click on the icon. it will not play?
Ok, from what I read on Microsoft, this software is NOT compatible with Windows Vista 32-bit or 64-bit. That was found directly from:
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Software&p=School%20Tycoon&v=Take-Two%20Interactive&uid=&pf=0&pi=5&c=PC%20Gaming&sc=Strategy&os=32-bit
However, checking the company's website, it mentions that some games that normally won't run in Windows Vista, can be ran in a "compatibility mode" which mimics Windows XP. Follow these steps and see if this corrects the problem:
  1. Right-click the shortcut for the game.
  2. Click the compatibility tab.
  3. Check the box for "Run this program in compatibility mode".
  4. Select Windows XP SP2 (or Windows 98 if XP does not work) from the drop down menu.
  5. Click Apply
  6. Click OK
  7. Start the game
It should run in Windows XP SP2. If it doesn't you can try Windows 98 to be sure. If neither of these work, unfortunately, you may be unable to play this game.
Mar 04, 2009 | Video Game Consoles & Games
Pc game not compatible with my DirectX
This game is for Windows 95/98/ME. And you dont specify what is your problem. The game doesn't install? Or after installation, it doesn't run? What exactly happens?
Anyway, if you're having problems running the game, you can try to:
If you're on XP or Vista:
- Install latest Direct-X (9 or 10, according to your OS, on Win98 and ahead you can install up to Direct-X 9): http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&DisplayLang=en
- If on XP/Vista, right-click on the game EXE and set compatibility mode (select properties, then compatibility, and on "compatibility mode" select to run the program as Windows 98 (try all options to see if it runs on any) - and try also the checkboxes below, to run the game in 256 color mode, on 640x480 resolution and to disable "visual themes".
Also update your graphics driver to the latest version available.
Mar 03, 2009 | 3DO Might and Magic 8: Day of the...
Super scattergories
Microsoft Windows 98 was an operating system used on a majority of personal computers from 1998 to 2000. Because of this, there are a variety of games available to play on Windows 98, but are incompatible with later versions of Windows. If you have Windows XP or higher, you have access to a "Compatibility Mode" that allows your computer to play those games. Activating compatibility mode is a simple procedure.
Right-click the file that you usually click on when you are trying to start a game.
Select the "Properties" option in the drop-down menu.
Select the "Compatibility" tab, then check the "Windows 98" box.
Select the proper video mode for your game under "Display Settings."
Select the "Apply" button to save your settings, and select "OK."
Double-click on your game's file to begin playing the game.
Nov 09, 2008 | Hasbro Interactive Super Scattergories for...
Sandrew
You're probably not going to find one. Vista lets you run old programs in 'compatibility mode' - actually, so does Windows XP. TSometimes it works, some times not but it's worth a try.
To use, you have to...
  1. right-click on the games' shortcut (either located on your desktop as an icon, or in Start -> All Programs).
  2. Once you right-click on the shortcut, click 'Properties'
  3. click on the 'Compatibility' tab at the top
  4. under the 'Compatibility mode' section, check the box that says 'Run this program in the compatibility mode for:'
  5. then choose 'windows 98' from the dropdown menu
  6. click ok when done
Good luck and I hope this helps! : )
Jun 24, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows 98 for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
