Question about Canon Office Equipment & Supplies
Error message: E000004-0401
Error message: E000004-0401. It's a ImageRunner C5158. Need help please!
Ihave a canon ir 3180c when started this errors E000026-040 comes, how can repair?
Posted on Feb 01, 2012
    Habit-Forming:
  • 71 Answers
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Posted on Sep 26, 2009
Hello, I have a Image Runner 5000s. It has an error message of E00000-0000. I have turn it off and on,but it only reboots half way before the error comes up again, then it shuts off shortly afterward....
this is error for thermistor fault, due to faulty thermistor or faulty temperature thank's to lamp or just temporary trouble wich can be reseted.
To reset:
While the error is showing before it shuts down:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * )
Choose: Copier>Function>Clear>error and ok
if needed turn te copier off and on.
If the error persist call service...
Hope that helps!
Sep 14, 2011 | Canon imageRUNNER 5000 Copier
Canon Image 2200 has a error message, Remove Waste Toner. How do we do this?
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Canon imageRUNNER 2200
I keep getting a message to press the shutdown
It looks like you might have a Fuser heating problem.
This can be caused by a blown heater element, or a fault in the temperature sensing circuitry. Usually Canon machines will lock out the device as a safety measure to prevent potential overheating and fire risk.
You will need a technician to fix this.
Feb 04, 2010 | Canon IMAGERUNNER 2230 Copier
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
E000 error message on canon imagerunner 2000 copier
Hello.
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Jan 19, 2009 | Canon ImageRunner 1600 Copier
Imagerunner 7200 Error E0000532-0001-need help!
hello you have to check the stapler unit and exactly the door loock from bottom under the stapler unit
Nov 10, 2008 | Canon imageRUNNER 7200 Copier
Service manual
I want user manual for cannon imagerunner 400 / 330 series
Sep 19, 2007 | Canon imageRUNNER 400S Copier
1,751 people viewed this question
old marine
old marine
