Question about Xerox Phaser 8500/DN Printer
I have an 07,010,043:8135 error on a Phaser 8500. I don't know how to fix this, can anyone help?
  • 2072 Answers
SOURCE: HELP!!! Phaser 8500 Error 09.035.43:28534
That is a cyan ( blue) ink stick count failure.
Look in your ink loader. First just try opening and closing the lid.
Then look for gaps in the cyan sticks. Most likely one is broken, cracked or otherwise jamed in the slot.
If you have to remove them, take a screw and screw it into the ink stick then slide it up the chute and out, then reload.
Hopefully someone didnt try to add or cut up a stick from a differerent phaser.
Thats your problem. Just a stuck cyan ink stick.
Posted on Mar 24, 2008
  • 2072 Answers
SOURCE: how do you print config sheet (mac address) from phaser 8500 pri
Here ya go.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Posted on Mar 18, 2009
dante777
  • 623 Answers
SOURCE: Phaser 8500 has error message 37,016.43:35730
the error 37,016.43 is related to the 50V power supply.You can download a service manual here.
The password to open the compressed file is: printer1.blogspot.com
Look at page 3-44 (page 110 in the pdf file) and you will find the steps to troubleshoot the error.
It also contains a parts list in case you have to replace the I/O board.
Fingers crossed and good luck!
Posted on Apr 01, 2009
  • 7 Answers
SOURCE: error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
brett207
  • 231 Answers
SOURCE: error code 37,016.43
This is an internal power supply error. The 50 Volt supply has a fault, or there could be a short on the supply rail.
There could be an error in the Head Maintenance, Deskew, or pick clutches.
I think you will need a qualified technician to fix this.
Posted on May 28, 2010
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Error code 37,016.43 Xerox Phaser 8500 Printer Problem I get this error when I power up. Printer won't do anything. What can I do to fix it?
May 25, 2010 | Xerox Phaser 8500/DN Printer
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8860 error code 08,030.46;21225
The Media Path Motor Stalled
Solutions ranked by relevance:
Make Sure There is no Paper Trapped in the Paper Path
Power the Printer OFF, Wait 30 Seconds and Then Power ON
Oct 01, 2009 | Xerox Phaser 8500/DN Printer
Apr 01, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Error
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
Error timeout
There is a firmware update for the Phaser 8500 that fixed this for me.
Sep 21, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
