Question about Kenmore 19001
USB port connection
I have a Kenmore R/W 1900 Model 385.93200 and it only has a connection other than USB, but my new laptop only has a USB connection. How can I get the two joined???
I had the same problem. I bought a USB to Serial Adapter (IOGEAR). Works great. I believe I got mine from Wal-Mart last year for around $25.
Look here: http://www.iogear.com/main.php?loc=product&Item=GUC232A&PHPSESSID=119a3d80d289daeb12185ff1ee32e7ff
Posted on Jan 13, 2008
I keep get a connection error. Ck that USB cable is connected and the power switch is on. Each time it comes up. Help
Make sure you have the USB plugged into the back USB ports on a desktop computer and try each of the different ports on a laptop computer. What Singer doesn't tell you (and probably isn't aware of) is that the back ports provide more voltage than the front ones (and is also true of certain ports on your laptop). The USB cable and your computerized sewing machine require more voltage than the other ports allowed.
Give this a try-it should do the trick.
May 01, 2011 | Singer Quantum XL-1000 Computerized Sewing...
I keep getting a connection Error Message. Please Check that USB cable is connected and power switch is turnedl. I just upgraded to a new computer from and older model computer
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. If you're using a laptop, keep trying different USB ports until you find one that works. Good luck!
Apr 29, 2011 | Singer CE-200 Quantum Futura Computerized...
My Bernina Artista 180E no longer works with updated Windows. Is it possible to upgrade so that I can still use my 180E and not have to buy another machine?
Just use the free download software from Bernina called Artlink. I used it along with a USB to Serial converter cable to connect to the machine. Works wonderfully. Allows me to still use my old Artista designer software if I want to on an older machine and then when I want to actually transfer the designs I use the laptop with the USB cable.
Feb 01, 2011 | Bernina Artista 180
Customiser 2000 will not connect to a laptop as it has a 9 pin serial port (female) and the laptops have a 15 pin (female) I have bought 2 different cables but none work it just says serial port did not...
Are you using a USB-to-serial adapter?
I *think* what the problem might be is that the COM port's not been set in Customizer. Within either of the Easy/Customizer apps, go to ScanCard>Communication Settings ... you'll open up a dialog box within which you can set which COM port your cable's going to use.
If you're compie savvy, you can go to the Windows Start button on Task bar>Control Panel>System>Device Manager>COM ports and SEE which COM port your cable's using.
But until your software knows what COM port your cable's using it will NOT recognize that you have one installed.
Please let me know if this doesn't help! Or if there's anything I can help with!! :)
Aug 01, 2009 | Janome Memory Craft 9000 Computerized...
HAVE LAPTOP AND BERNINA 185 EMBROIDERY SET UP HOW CAN I MAKE CORRECT CONNECTIONS WITH USB PORTS, ETC.
You must purchase a Serial (port) to USB (port) adapter. I got mine at Radio Shack. Hope this helps
Jan 07, 2009 | Bernina Artista 180
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Can't connect my Bernina 170 Embroidery unit to my computer
I just bought a new laptop and upgraded to V.6. Since I have always used a magic box I didn't know how to attach my bernina 170 directly to the laptop. My bernina dealer said that I would first need a serial to usb adapter since my machine is old enough that it doesn't have a usb port on it. Make sure it doesn't have the screws on the serial part because they will not allow you to attach it to the machine. He also said that I may have to make a new com port as most pc laptops only show 4. I did a search of the computer and found how to make a new com port. A little more fiddleing around with the laptop and cables and restarting both then it somehow recognized that I had made a new com port. Voila. It now works. (I am a Mac person). Hope this helps. margaret
Jan 04, 2008 | Bernina Artista 170
Card reader connection
Buy a USB to Serial Adapter. I bought one made by IOGEAR and have had not problems,
Dec 17, 2007 | Kenmore 19001
Husqvarna rose
go to radio shack with the lap top and the embroidery card reader and show the things to a knowledgeable tech and get a adapter. now, do you have the software for the card reader so it can be installed onthe laptop? how about the software interface?
Nov 11, 2007 | Husqvarna Designer I
Sewing Machines Logo
60 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
