Question about Bernina Sewing Machines
The USB port on my Bernina Artista 200 embroidery computer does not read my USB device. The USB icon is grayed out on my screen and will not read the USB device which contains my embroidery designs I am trying to load and sew. Thank you for any help!
dupina
  • 110 Answers
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Posted on Dec 18, 2007
HarryHarley
  • 343 Answers
SOURCE: I have lost my instrtuction manual for my Bernina
You can get one here:
http://www.sewusa.com/Sewing_Machine_Manuals/Bernina_Manuals/180_Instruction_Manual.htm
Posted on Dec 24, 2009
SOURCE: DOES THE BERNINA BERNETTE DECO 600 ACCEPT .ART
Not sure if you found anything out, but Deco 600 uses PES format only.
If you have the software (Deco Wizard) sometimes you can change it to PES and save the design.
Good luck
Posted on Feb 15, 2010
SewExpress
  • 41 Answers
SOURCE: USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Posted on Jun 27, 2010
RickE1
  • 202 Answers
SOURCE: Artista embroidery program version 3.0 and Windows 7
For other versions and probably yours...
You'll need the following service packs to use BERNINA Embroidery Software V5 aand under Windows® 7 / Windows Vista™ operating system:
  • Service Pack 2 for BERNINA Embroidery Software V5 (V5.0W)
  • Aurora driver for 64-bit Windows® operating systems
  • Latest dongle driver
  • EConPC 3.1 & ADX 7.14
You'll find them at www.bernina.com\downloads
Hope this helped.
Rick
Posted on Jul 12, 2010
Need Bernina Artista 200 manual ASAP
You can download a manual from the Bernina web site.
BERNINA Support Machine and Accessories Finders and Software Support...
Then go to "Search Support Info for Bernina Models"
BERNINA artista 200 Support BERNINA
Jul 13, 2016 | Bernina Sewing Machines
Is bernina artista 180 embroidery module compatible with bernina artista 170
Yes, The BERNINA Artista 180 and the BERNINA Artista 170 do in fact use the same Embroidery Module.
Sep 28, 2015 | Bernina Artista 170
How do I install Bernina Artista Software V5 on Windows 8?
Contrary to what Bernina has said about their software (Bernina Embroidery Software v5), that particular software CAN be installed AND ran in Windows 8 with no issues whatsoever. When you install it, it will perform normally (not go to a blue screen like Bernina says), then it will ask you to insert the dongle. After installation, go to the Bernina Embroidery icon and right click. Select troubleshoot compatibility. The computer will run a test to see what system you should run the software as. It should say Windows XP Service Pack 3. Select next. Now double click your Bernina software and it should start up fine. Hope this helped.
Dec 30, 2012 | Bernina Sewing Machines
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
Happy stitching,
Kim
Jun 23, 2010 | Bernina Artista 180
I need to order one I lost mine bernina 180 cable
This is for connecting the embroidery machine to the PC?
You will need a cable with USB port A on one end and USB port B on the other - both male.
You can get this style of cable at an electronics store.
If this is not what you mean, then you need a Bernina dealer to order one for you.
Feb 20, 2010 | Bernina Artista 180
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
HAVE LAPTOP AND BERNINA 185 EMBROIDERY SET UP HOW CAN I MAKE CORRECT CONNECTIONS WITH USB PORTS, ETC.
You must purchase a Serial (port) to USB (port) adapter. I got mine at Radio Shack. Hope this helps
Jan 07, 2009 | Bernina Artista 180
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Embroidery
If you doing an embroidery, it has to have something to do with the way the design was digitized. We have a BERNINA ARTISTA 180 and have never come across this problem. The embroidery machine only reads what is on the disk. Try putting your design through the computer.
Sep 07, 2006 | Bernina Artista 180
Sewing Machines Logo
117 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
