Question about Lexmark X5470 All-In-One InkJet Printer
My paper load crooked, how can I get it straight again?
2 Suggested Answers
Printtech
  • 1087 Answers
SOURCE: paper is pulled through crooked
This can be caused by several factors. It could be that there's something(like small foreign objects in the paper feed area) causing the paper to get crooked. It can also be caused by improperly adjusted paper guide or the paper is not in good condition.
Paper Feed Rollers Are Rolling But the Paper Is Not Feeding
How the Accu-feed Paper System Works
Posted on Mar 24, 2011
Roll feed Paper will not load
You need to make sure that the leading edge of the paper is straight.If the leading edge is crooked or angled it will often cause a load issue. Also make sure that the roll is mounted properly on the spindle.h
Jun 26, 2015 | HP "Designjet 111 24"" Wide-Format Inkjet...
LOADED PAPER I ...GOES CROOKED
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Apr 04, 2012 | Office Equipment & Supplies
Prints crooked
The paper is not being pulled into the printer straight.
There are small sliders that rest next to the paper in the loading tray, you are required to push these so that they slide over and rest directly next to the stack of paper. This will guide the paper into the printer straight so that the paper does not get pulled in crooked.
Feb 28, 2011 | HP DeskJet 5550 InkJet Printer
My canon pixma ip90v is drawing paper in crooked
Your Pixma's paper holding drawer has adjustable feeding attachments on the front and left side you can use to make sure the paper is square and secure in the tray. This will help your paper load straight.
I hope that helps.
Jul 14, 2010 | Canon Office Equipment & Supplies
Paper jam, but no jam + paper feed problem
check to make sure there aren't little pieces of paper jammed at the ends of the roller. if you can pop out the roller easily you may find tiny pieces of paper still lodged in there
Dec 29, 2009 | Office Equipment & Supplies
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper feeds through straight at first then scans crooked at the end
This could be because of unclean rollers. The scanner picks paper neat, but images is crooked. This is because paper is stuck on one side and the other side is contnuing on the other, giving it the skew. There may be something sticky on the roller, possibily a left over cellophane tape. Remove it and clean with Isoporpyl alcohol. Dont use solvents.
S. Mohan, Chennai, India
Oct 15, 2008 | Canon DR-2580C Path-Through Scanner
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
Crooked Copies
dear sir please check the upper heat roller claws set,may be one of them is bended up
Sep 27, 2007 | Panasonic Workio DP-4530 Copier
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Lexmark X5470 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
