Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Pt 53wx53 convergence
I recently replaced both convercence chips myself and successfully fixed the drastic issues i was having with on screen distortion in my pt-53wx53 projection tv. while the picture is almost back to what it was before the problem, i still have issues on the right and left part of the screen with the red convergence not being perfectly alligned. is this something i could fix by accessing the service menu and if so how do i get into the service menu??? i have done the regular on screen convergence adjustment several times but it does not have much affect. it is a minor problem that i could live with if i had to but i thought there might be an easy solution...
  • 3 more comments
  • jimcain Jan 24, 2008
    Same here except my red wont go right. Did I mis solder a ic pin? Will service menu help?
  • spring08 Feb 11, 2008
    I had similar convergence problems on my Panasonic PT-53WX53 as many have posted here. Without previous experience, I attempted to replace the broken IC chips on the main board. Unfortunately I pulled off several tiny pieces of the circuit coating when I tried to remove the IC pins from the board. I would assume that I have damaged the main PC board and need to replace it (very expensive at $280). However, I am not sure how to disconnect the high power cable from the board, and how to disconnect this main board from the board connected through three connectors. Can someone help me? I would greatly appreciate!
  • mrfixit456 Feb 24, 2008
    not of the solutions here see to be complete. I cannot get the red to converge to the right. Also the verticle bar on the red is curved. Please advise.
  • Sparky_2007 Mar 16, 2008
    Hello, I have a simillar problem for my unit, the green is way off, can't converge with blue and red, and the green curves on the top and bottom of the screen. I read on some post that they replaced the IC's, Any idea which one are those? Any help will be greatly appreciated.
    thanks a lot
  • Joey Arceneaux Mar 19, 2008
    Sorry if I keep posting in the wrong place, I'm still learning to use this site. I have a Panasonic PT-47WXC43G with convergence problems. I replaced both the STK 392-110 IC's and checked the adjacent resistors. The resistors were all within tolerance but when I turn on the TV it powered up momentarily then shutdown on its own. The power light is blinking. What should I check next?
I have a Panasonic PT-47WXC43G Projection TV. I started having bad convergence and commented on this site. I replaced both the STK 392-110 IC's and checked the adjacent resistors. The resistors were all within tolerance but when I turn on the TV it powered up momentarily then shutdown on its own. The power light is blinking. What should I check next? Can anyone help?
Posted on Mar 19, 2008
I am sorry, I don't have a solution. I have the same issue. I replaced the two chips, but I still get double images with green shadow. It is not that bad and I can live with it, but is there anything I can do to fix that also? Does it have anything to do with my soldering? Or is there any bad resistors? TV works fine with a little bit of adouble image with green shadow.
Any suggestions? Thanks,
Posted on Feb 05, 2008
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a Panasonic PT-53WX53 RPTV. Recently, the very top and very bottom are cut off. Using the Aspect button on the remote accomplishes nothing except when putting it in 4:3 mode. I can get into the...
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Replaced convergence chips in my 53" panasonic
If the chips are not fakes then check your soldering for shorts.
For all others who are having convervence failures this is a common problem. You can get all the parts from www.TvRepairKits.com
  • Screen Looks 3D
  • Colors wont align
  • No Audio or Video
Nov 10, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Everything looks like its in 3D vision. Im pretty sure somthing isnt alined right so i was wondering what i can do to fix it.
Replace convergence output ICs in your tv to fix this 3D look picture, it happens due to convergence output chips failure.
Local tv repairman will fix it for you if you have no prior experience of part replacement in tv circuit board with proper tools.
Sep 26, 2010 | Panasonic PT-53WX53 53" Rear Projection...
I have a Panasonic HDTV Model PT-53WX53G. I am getting a 3D / Double screen effect.
This is the convergence chips. They are 18 pin Amplifier IC Chips that control your three tubes to line the colors up. They are only about $20 each (there is two of them). They are difficult to replace if you dont know how to solder/unsolder. There is usually at least one resistor or fuse that will blow when the chips go out, you must replace this also. If you have no experience in electronics then i'd suggest you take the set to a pro.
Aug 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
PT-53wx53g Convergence issue?
Both convergence amplifiers should have been replaced at the same time. If you can get your hands on a service maual, replace both of them, and go through the convergence alignment in the manual.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence Problems with red to left of screen.
Replace Both STKs convergence ICs number of part will be on them STK392-110 if this is the number use 180s To order Parts Go To www.electronix.com or Call 1-900-223-3205 These ICs are big black chips.
Dec 14, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Screen shadowing with colored lines
This is most likely a convergence problemand can easily be fixed. If you can solder you can repair this yourself. First try resoldering the pins on the convergence ICs. If that failes to resolve the problem, replace the ICs. THese are large black Ics attached to a heatsink and may be marked STKxxx.
Keep us posted.
Dan
Jun 27, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
280 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
