Question about Pentax K100D Digital Camera
Memory Card error message
I have two Pentax K100D camera bodies but one Camera displays message Memory Card Error when a 4GB memory card is inserted but not when other sized cards are used, the other camera does not.
The Camera House rep said i may be able to configure the card to my camera by down loading a program to the to the card from the Pentax site on the internet, which program do i look for.
I have tried formatting the card with no change to the error message.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
The K100D works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot is is electronically incompatible.
Posted on Aug 24, 2012
2 Suggested Answers
mail541
  • 58 Answers
SOURCE: Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Posted on Jan 21, 2009
I just put a new 4GB SD card into my Pentax Optio S4i camera. When I power it up I get the message "memory card error" Tried another card and got the same error message. Any...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 02, 2011 | Pentax Optio S4i Digital Camera
When inserting a transcend 4GB card the camera shows "card error" when i then try to format it the camera locks and will not do anything including switching off. What is wrong and what do i do R L...
HI,
try to use memory card to other device like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error message, camera needs service.
Jul 16, 2008 | Cameras
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
What Memory Cards will work?
Hi,,
Unfortunately, the Pentax K100D is not SDHC compatible, which means that the camera can be equipped with a maximum memory capacity of 2GB.
It is also advisable to choose a fast version of the Secure Digital memory card, such as Ultra II or Extreme III by SanDisk. I would recommend using a memory card of at least 512MB, or even 1GB if you can.
Hope this info helps
Dec 03, 2009 | Pentax K100D Digital Camera
Ive bought a new memory card for my pentax optic e10 camera when ive inserted it it is reading memory card error what can i do
This camera takes an SD (secure digital) memory card according to amazon and google. Looks like your using a Sony Memory Stick Pro Duo which would not be compatible.
Try using an SD card.
Jun 13, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Pentax K200D Digital SLR - Error Message "f - - "
This can also happen when the lens have an aperture adjustment ring, and it is not set to the "Auto" setting ("A", on my Sigma)/
Dec 25, 2008 | Pentax K200D Digital Camera with 18-55mm...
My pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
Oct 01, 2008 | Pentax K100D Digital Camera
Count down on memory card
Hi!
The K100D's lcd read-out is limited to displaying 999 as its maximum. This means that the card is capable of storing 999+ pictures. Once it gets to a point that the card can only store 999 pictures or less, then it will begin to count down.
Hope this helps!
Sep 26, 2008 | Pentax K100D Digital Camera
4gb Memory card error
In order to use 4gb memory your camera has to be approve for SDHC use.
If it isn't the most memory you can put into your camera is 2 gb
Jun 14, 2008 | Pentax Optio S50 Digital Camera
Pentax K100D Digital Camera Logo
267 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
