Stylus dropped on rotating turntable.
I recently purchased a Grado Black cart for use on an old BIC 960. Of course, the first thing that happened was that the automatic turntable dropped the tonearm onto the platter. I obviously screwed up and left it powered on, but wonder how bad? Is there a way to tell if the stylus was damaged without a tech looking at it? Thanks!!
  • Anonymous Mar 23, 2014
    Every thing works except for the turntable, which I would like to get working again.
I am not an expert but know of someone who helped me in the past with a Thorens TD115. This fellow Dariusz at Q-Audio will be glad to offer some advice. Why not give him a call at 617-547-2727.
Posted on Sep 25, 2009
Platter vibrates; doesn't rotate smoothly
Do one thing Remove the palter and put one drop of lubricating oil in the center shaft. Also put one drop in the motor shaft. Be carefull do not drope the oil in motor pulley. If so clean the pulley with a cloth. Because it will cause slipping the belton the pulley.Then put the plater back. Rotate the plater with arms for some time. Then check.
Ajin
May 07, 2012 | Numark ttUSB Turntable
About 11 months ago I bought an Elliptical upgrade stylus for the PL-990 and it worked great. Recently, it started giving me problems. The left channel would be very distorted and also would fade in and...
Very odd! Sounds like it's not fitting in right. Are you sure that you have the right type of stylus for the cartridge? If in doubt replace the entire cartridge & Stylus. If it still plays up then it's in your amp after that course of action.
Aug 18, 2011 | Pioneer PL-990 Turntable
Can you just replace the needle of a grado f3+ stylis?
Yes the correct replacement stylus for a Grado F3 is the Blue stylus. This is the stylus that will fit the older F3 model cartridge.
Jun 09, 2011 | Application Techniques CaptureEze Pro...
Get no sound. have grado f3+ cartridge.replaced styluswith grado prestige blue. could the wires to cartridge be mixed.
(1) Yes, wires could be mixed. Here are the codes L = White, LG = Blue, R = Red, & RG = Green
(2) Wires on tonearm base are disconnected.
(3) RCA plugs might need replacemement.
(4) Cartridge is defective.
(5) Plugged in the wrong input of the receiver.
Dec 10, 2010 | Philips WMM142211 Turntable
As the stylus touches the record the turntable stops rotating
If this is a belt drive turntable you need to replace the belt. Make a note of how it fits, before removing the old one.
Sep 25, 2010 | Aiwa PX-E860 Turntable
Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Feb 02, 2010 | Audio Players & Recorders
Poor quality audio from a new Grado Black series cartridge
Look around for a bad conection, perhaps inside the turntable.
Aug 09, 2009 | Audio Players & Recorders
Old Philips turntable 312 No sound
I am in a similar situation. I recently discovered that exact model turntable in our storage room. The Philips 312. While looking it over, I noticed the stylus is broken. I was wondering where you purchased yours?
Mar 27, 2009 | Philips Audio Players & Recorders
Technics SL-D303 motor noise
CHECK TONEARM GROUND TO SIGNAL GROUND WIRE OR SOCKET FOR CONT.
Mar 13, 2009 | Technics SL-1200MK2 Turntable
One channel vocals drop out
yes, it is very likely the stylus. the stock needle is conical shaped like a ball point pen. You might have a tonearm that is out of alignment but usually it's the needle. It is possible it is just dust on the tip but if it occurrs in consistent areas of the record, then it is likely that the music is just too demanding for the LP2D you will either have to use your old technics which is likely better quality or you could try upgrading the stylus on your LP2D.
If you do a yahoo search for "4-211-DE-GUARD" with the quotes, the 1st result will take you to an elliptical upgrade over the stock needle. The elliptical tip will pull more info out of the grooves and into your computer for further processing.
Jan 16, 2009 | Audio Technica USB Turntable
123 people viewed this question
 Grubhead
Grubhead
