Question about Dell 3110cn Laser Printer
There is an error code that came up after I change all of the ink cartridges... The printer does not respond at all to my pc commands or when I press any of its buttons... what is going on...???...
  • PrintDocta May 11, 2010
    What is the error code ?? Try changing the cartridges one at a time, see if only one of the 'new' cartridges triggers the error message
4 Suggested Answers
sayer268
  • 147 Answers
SOURCE: Printer LCD reads (hardware error: 0502). PC
You may need to try the dell support folks, a link is attached.
If you are sure you removed all the packing from the printer, the carrier can move freely back and forth, that you installed the software and then plugged the printer into your PC, try this link.
http://support.dell.com/support/topics/global.aspx/support/hardware/hardware_portal?c=ca&cs=cabsdt1&l=en&s=bsd
Feel free to PM me with further questions
Posted on Jan 16, 2011
andik_guru
  • 146 Answers
SOURCE: printer will not print also ink cartridge say
manually you can detect problem when do this
try same cartridge from other printer, if its ok mean you have to replace it with a new one.
Posted on Mar 04, 2011
  • 180 Answers
SOURCE: I have a Dell v313w
1) Uninstall your printer.
2) Hook up the original usb cable to your laptop, as you did when you originally hooked up the printer.
3) Reinstall the printer with the disk as if it were fresh out of the box.
4) Remember to do exactly as the disk's instructions tell you to do.
If the ink cartridges aren't Dell compatible then you have just wasted ($35).
Posted on Aug 31, 2011
While I was printing, it stoped in middle of the page and in the screen seys: Cartridge error, error: 1203 I turned of, change the cartridge, start again, but does not change. Please, what I should do?
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using FIxya
Sep 09, 2011 | Lexmark X7170 All-In-One InkJet Printer
I have changed the ink cartridge but now have error message "check printer 5100", what is this problem ..Thanks
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
Does not print, responds with paper jam. No paper jammed. Clean sheet of paper passes through. Could a buildup of dust be the problem and its age. Tried cleaning roll by command and changing the ink. I...
What you could try is let the printer to reset.
Remove both ink cartridges.
Close cover and turn off printer.
Unplug printer from electrical outlet.
Wait 15 minutes. This will let the printer to clear memory.
Plug printer back in.
Turn on printer, printer would cycle to the start position.
E5 error would appear.
Install ink cartridges.
If nothing is in the printer that prevent the printer from recycling.
There should be no paper jam error.
Jan 04, 2011 | Canon PIXMA MP170 All-In-One InkJet...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 07, 2008 | Brother MultiFunction Center MFC-440CN...
HP Photosmart printer Ink System Failure Error 0xc18a0201 happens every time I start it.
You press the button to turn off the printer.
Unplug the power cord from the back of the printer. Unplug the power cord from the back of the printer.
Remove all the ink cartridges. Remove all the ink cartridges.
Wait two minutes. Wait two minutes.
Plug the power cord into the back of the printer. Plug the power cord into the back of the printer.
Press the On button to turn the printer on. You press the button to turn the printer on.
Install the ink cartridges when prompted. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the error code does not display, the issue is resolved.
Dec 05, 2008 | Computers & Internet
Ink system failure
Wait two minutes.
Sep 14, 2008 | HP Photosmart C6100 All-In-One Printer
Printer not responding
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
- unplug cable
- plug cable
Run the software.
oke
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Dell 3110cn Laser Printer Logo
55 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
