Question about Lexmark JetPrinter Z11 InkJet Color Printer
My Lexmark printer triple strikes each letter 3 times
Right Cartridge is incorrect. But we never print in color.
Lexmark Printer Problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/13953
My printer Z12 Color Jetprinter is printing triple letters (printing on top of each other). ..... I have a Lexmark All-In-One X5150---It says "color cartridge missing" butthe ... We removed the ink cartridge and looked on the back of it and realised that .....to the right side of the computer ..if someone can tell me whats wrong or how ...
Lexmark Reset ink cartridge ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/35235
Jun 3, 2009 - Does any one know how I can reset my ink levels in the Lexmark All inone ... The best way to reset any lexmark inkjet is to buy a real printer. ... fool the empty ink cartridge signal on the Lexmark but putting a piece of "that never ..... So sure the printer prints but is it just using up the color cartridge to make the ...
[PDF]5000 Series User's Guide - Lexmark
Jan 18, 2016 | Lexmark X5070 ALL-IN-ONE InkJet Printer
I keep getting a paper jam error with my Optra S 1855 printer, but there is no paper jam. This error interchanges with a message asking me to Change the paer in tray 1 to letter size, but it is already...
Open the tray and make sure the green paper lever is set to letter mark, both at the bottom of the paper and the one on the side. And yes, if you haven't used it for 3 years, you should clean the dust that settled inside your printer over time.
Dec 06, 2010 | Lexmark Optra S 1855 Laser Printer
The striker appears not to strike the Daisy wheel letters firm enough to produce a dark and clear letter. Many times the result is a letter not fully printed and it appears to be lighter along the left...
Please check the ink ribbon. There are two types of ribbons. The plastic one can be used once and if you try it the second time then there is no guarantee that all letters will appear fine and legible. (as may be happening in your case). The other is the cloth ribbon. This can be reused and it keeps fading as you keep repeating it. But in this case all letters are faded and nor selective.
Nov 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
Messagr: load mp feeder letter
try to check on this link:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_T632&page=product#3
Nov 03, 2009 | Lexmark T632 Laser Printer
Brother HL 2170W printer fried by lightning?
Wait until the printer cools and try again. As you said, you've tried from different power sources (including a different outlet). If still the same problem, unfortunately, your printer got the "hit" instead of the protected power strip.
Jun 29, 2009 | Lexmark X7350 All-In-One InkJet Printer
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark Optra T610 keeps saying "change tray one to plain paper"
3 possibilities
1) the paper size sensor in the tray(those teeth on the size of the tray) is broken
2) The sliding paper guide is not pointing precisely at Letter
3) Your paper type is set to something other than Plain Paper.
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Why does my lexmark x73 jam half way
1-tires are dirty and not picking up on time, clean w/alcohol
2-does it say Letter? or diff size
3-something in the paper path blocking it
Sep 15, 2008 | Lexmark X73 All-In-One InkJet Printer
Double striking letters in middle of sentence
This was one of the BEST All-In-One printer HP had ever made
Its a real fortune to still have it.
Verification of color out – happens only after keeping the unit idle for quite some time.
1. Are the cartridges out of ink – check ink levels
2. check self-test report patterns (missing lines or streaked bars)
3. Look for missing colors or ink smears.
4. Was this issue showing up because of any one single color?
5. Was it stored in a warm environment (Stored under direct sunlight?)
6. Manual Cleaning & Cleaning from Driver
Also try the steps in this below link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00043846&dlc=en&product=79499
Good Luck
Mar 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Open Questions:
I have a Lexmark Z11 that sat unopened in the box for several years until it was given to me as an emergency printer. The black ink cartridge had been pilfered by the original owner ( he got several of the se printers on clearance for $15 each). I bought a remanufactures high capacity cartridge. It workef fine for the three days of printing I did last week (about 25-30 pages of resumes and reference letters). When I went to use it a week later, it goes through the motions of printing but no ink is put on the page. I ran the clean cartridge several times but still no ink. I tried the new still-in-the-box color cartridge and did get color on the page in the alignment trial, but it was faded and full of white lines. I figured the cartridge was just old. It could be the ink leaked out of the remanufactured cartridge, but when I gently blew on the air hole I got a small splat of ink. (I used to be a sales rep for Canon printers a dozen years ago and we were told to do that to see if the cartridge still had ink.) I deleted and reinstalled the printer, unplugged and replugged cable and power cord twice. The printer receives the command and goes through the motion of printing, but as I said, no ink is put on the page. I have come to the conclusion the perhaps the remanufactured cartridge is at fault and I should take it back for an exchange, Can I get your take on it - is it the cartridge or the printer? Thanks! -Kathleen Brockway
Mar 01, 2017 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark JetPrinter Z11 InkJet Color Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
