Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
Ipod 20gb showing file folder with the triangle or Do Not Disconnect then after a few seconds will reboot, dont know if i can fix, or just throw away
    Problem Solver:
  • 9 Answers
Only suggestion I can make is to turn on and off 5 times last to on then hold down middle and top of click wheel till apple logo appears. This should reset your ipod.
Posted on Oct 03, 2009
Dear sir, I have locked my ipod Model A1136 and i dont know the password. I have never change it. Does it got a specific code for a new product like Nokia phone 12345 for the first access. And if not what...
if your ipod docks onto itunes but is still locked when you disconnect it, you do NOT have to reset it! all you have to do is follow these next few steps.(this is done on a windows xp system)
Go to my computer>devices with removable storage>ipod(-random letter goes here-:) go to the top.
click the button that says Tools and go down to Folder Options and click it.
a new window will apear that has three tabs. the middle one says Veiw. click that.
in the veiw tab there will be a Advanced Settings box. under Hidden Files and Folders, click the dot that says "show hidden files and folders" next to it.
close the small window and click a shadey file called ipod controll. if you dont see this reset the page by clicking th backward and then forward button up in the top left hand side.
then click a folder that says device. in that folder you will see a file that says "_locked" and it should have a small size (i.e. 1-7kb).
delete this file and undock your ipod from the computer through itunes.
when it restarts it will most likely be unlocked. if not, proceed with the other way to unlock your ipod above.
best of luck. i repair the worst of ipod senarios, and i know how frustrating they can be.
Dec 31, 2010 | Apple iPod MA446LL/A MP3 Player
How to unlock factory volume lock,i dont have the code
why dont you try this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Dec 25, 2009 | Apple iPod nano
Need to unlock volume control Nano ipod Apple
Please follow these steps for unlocking your iPod;
Please plug in the I POD to the compuer using the USB cable as first, you have to enable showing hidden files and folders to do it;
Click start-> MY COMPUTER(On the compuer screen)
Go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders", click OK.
Now, plug your iPod to your computer. You will see your iPod in "My computer" as a removable drive. Open it by double clicking, go to "iPod_Control" folder ,then "Device" folder. You will see file named "_volumelocked", please delete it.
Eject your iPod. Then, restart your iPod, You can do this by holding down the center and menu button for at least 5-6 seconds. Your iPod screen will go black and then you will see a Apple logo.
After reboot, you will have no limitations about sound.
Please rate me if you are happy with the level of support provided in regards to your query.
Sep 15, 2009 | Apple iPod nano
Unable to unlock volume control on nano ipod
Jul 19, 2009 | Apple iPod nano MP3 Player
MY IPOD IS SAYING GO TO WWW.APPLE.COM/SUPPORT/IPOD
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod is dead and needs to be replaced.
If the iPod is showing the "Folder/Exclamation Point" icon, this means that the logic board (the circuit board) inside the iPod is no longer working properly and needs to be replaced in order for the iPod to work.
Feb 12, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Ipod 3rd Generation
Test the hard drive by holding menu+centre to reset and immediatly holding left+centre when it reboots to enter the ipod diagnostic menu. Use the right arrow to highlight the Memory or HDD menu. Select it and you should be able to find out if the drive is dead.
If the drive is ok, try restoring the ipod through itunes.
Post back here if the drive is wrecked.
Jan 25, 2009 | Apple 20gb Ipod Mp3 Player With Click...
I Can't unlock my Apple Ipod (black)
On MAC :
  1. Enable hidden folders.
    killall Finder
    killall Finder
  2. Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
On Windowsç
    In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
  2. Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
Sep 18, 2008 | Apple iPod MP3 Player
VOLUME
Warning!
  • Don't listen to music to loudly. It will destroy your hearing.
Steps(Windows)
    Go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". I honestly do not know how to do this on a mac. I'm simply stupid.
Apr 16, 2008 | Apple iPod classic MP3 Player
Ipod u2 edition not working
Start with this troubleshooter,
Its for nano but, there is no spesific troubleshooter for u2. So Try it and tell me how it turns out.
Feb 23, 2008 | Apple iPod U2 Special Edition MP3 Player
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
228 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
