Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
I RECENTLY PURCHASED AN HP 6500 , HOWEVER THE PROBLEM I AM HAVING IS WHEN SCANNING DOCUMENTS THERE IS A BLACK FINE LINE RUNNING DOWN THE PAGE . WHAT COULD BE THE PROBLEM ! BY THE WAY , I JUST PURCHASED THIS PRINTER 3 WEEKS AGO.
MUKHTAR
  • 2022 Answers
SOURCE: black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Posted on Nov 30, 2007
shortyz1123
  • 9 Answers
SOURCE: scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Posted on Jan 07, 2008
SOURCE: Problem when scanning
If it is under warranty, contact HP.
Believe it or not, there probably is something in your scanner. Often times it is a very small piece of dust/fiber. If you are using the document feeder, the check the small piece of glass as the scanner bulb remains stationary and the paper is fed by. If you are laying the paper on the glass and scanning, then you will need to look at the scanner bulb itself. Run a scan with no paper and see if you see anything. If not, you can try to take it apart and clean the bulb (but do not touch the bulb with your bare fingers), with a light wipe of a tissue. If after cleaning, it either moves or goes away, then it is dust related. If it remains in the same position on the page, then there is a scanner bulb problem.
Posted on Jan 23, 2008
SOURCE: HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Posted on Oct 01, 2008
  • 3 Answers
SOURCE: Scanning and faxing
clean the glass with soft cloth and smallest amount of water, rub hard to get off the small dots that cause the lines even if you can not see any
Posted on Oct 27, 2008
OfficeJet 6500 Pro crashes when scanning
Return to supplier for repair or preferably replacement. Better yet an entirely different machine. The entire Officejet Pro range is poorly made.
Jul 28, 2014 | HP Officejet 6500 All-in-One Printer
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
I purchased a HP Officejet 6500A Plus printer on the 1st of May 2011 and I have been using since then - mostly trouble free. This issue which showed up about two days ago is as follows. Using the...
> purchased on 01-MAY-2011
The warranty is still valid. Contact HP to find an Authorized Service Centre;
they will repair/replace it, for free, under warranty.
Aug 04, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Scanner HP 6200
Not the scanner -unless you have allowed the page framing to slip- check that out More likely the printer- and an indicator that the waste ink tank is over full and needs servicing. Goto www.fixyourownprinter- and log into your model to see how to do it.
Aug 12, 2007 | HP ScanJet 5100C Flatbed Scanner
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
