Question about McCulloch Garden
I have a broken fuel tank - McCulloch Garden
  • 1,498 Answers
Hi Graham,
If the problem is a leak and not something more serious, I have a quick, cheap and permanent fix for you.
Go to an auto parts store, They have a two part solid epoxy sold to repair batteries and Gas tanks. Cost is a couple bucks.
You don't even need to drain the tank. Knead it together, and jam it into the crack, hole or whatever. In 15 minutes it's as good as new.
Hope you found this to be very helpful,
Mike
Posted on Sep 25, 2009
Car was running fine and then just died. try starting it and turns over and runs for a second and dies
Clogged fuel supply?
These symptoms are indicative of such a problem.
Dirty fuel filter.
Clogged or obstructed fuel line.
Low fuel supply.
Debris in tank.
(Were you near empty?).
Obstructed supply pick up in tank? Or broken. This is possible, if pickup was broken, the line is now higher and you could have an 'out of fuel' type symptom, at 1/4 tank.
Good Luck
May 16, 2015 | 2008 Ford Focus SE Sedan
" What is Fuel Level?"
Maybe a ...Clogged fuel supply?
Dirty fuel filter.
Low fuel supply.
Debris in tank.
Good Luck
How do you replace the gas tank on a ryo 8548 gas blower
Why are you trying to remove the fuel tank just for broken fuel line?
These can be normally be replaced while the tank in still mounted using the appropriate tools.
As for removing the tank you probably need to remove that starter assembly or may need to fully disassemble the casing.
Oct 04, 2014 | Ryobi Garden
How to change fuel line on Husqvarna Trimmer 128L
They are juat a pull in fitting. Get access to the fuel tank, the broken fuel line should just pull out the tank. The new full line goes back in through the top, just pull through into the tank until the hole in the tank sits between the 2 flanges on the fuel line.
Mar 20, 2013 | Husqvarna 128L Line Trimmer
1970 yamaha u5 keeps running out of fuel tank is full
Hi, Anonymous always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Vacuum line to fuel valve clogged, cracked, pinched, bent, broken, or missing*
5. Faulty vacuum line switch/relay
6. Petcock clogged or diaphragm cracked, cut or torn*
6. Fuel line from the fuel valve/petcock to the carburetor clogged, cracked, pinched, bent, broken, or missing.
7. Vacuum lines to the mechanical fuel pump clogged, cracked, pinched, bent, broken or missing*
8. Faulty electric fuel pump and or wiring*
9. Fuel line from the fuel pump to the carburetor clogged, cracked, pinched, bent, broken, or missing*
10. Carburetor inlet fitting clogged.
11. Carburetor float and or needle and seat stuck.
12. Carburetor overflow line clogged, pinched, or bent.
13. Vacuum line from carburetor deacceleration valve not zipped tied*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a wonderful day.
Letting tank get low risks more than just running out of gas
Scooter shuts off when stopping red lights stop signs waiting to turn etc...
1965 Yamaha 50 5 Mate Riders Manual
OEM parts for Yamaha
Yamaha U5 owners manual 3920
Sep 25, 2012 | Yamaha Motorcycles
My Husqvarna 24C fuel pipe in the fuel tank has perished and broken can I replace it and if so how?
Fuel lines are a push/pull fit, the fuel line has 2 flanges, one should sit either side of the fuel tank. I will send you a link to the parts manual.
May 31, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
Have 2 gas lines dangling in gas tank, mcculloch 42c, 36cc, older, one line has filer other for primer????? or did it come disconnected
Hi perfecthelme...
Those are broken fuel lines your are seeing and a fuel filter inside of the tank
I will include a fuel routing drawing.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash,broken pieces of fuel line,etc. from the fuel tank.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Please take time to rate me
Sep 24, 2011 | Garden
Gas guage doesnt work
It sounds like a problem with the fuel gauge sender unit in the fuel tank which has worn out and gone open circuit and needs replacing. Access to the unit is usually through a removable plate in the floor in the rear of the vehicle. Disconnect the wiring connector and any hoses and then remove the securing screws. Replacement is done by reversing procedure.
Sep 16, 2010 | 1986 Lincoln Town Car
Fuel gauge stopped working
this is usually caused by a broken fuse or a broken float in the fuel tank.
check the fuse first (under the dash or under the hood)
if thats good then check the float. It is inside the fuel tank. you will need to remove the back seat of your car. everything is located under the back seat.
remove the tank cover protector
then remove the fuel pump or float by unbolting it from the tank.
Feb 26, 2010 | 2000 Mitsubishi Eclipse
2000 chevy pickup
Most probably if you take out your gas pump/sending unit assembly out of your fuel tank you will find a broken fuel hose on the assembly. The actual pump rests in the bottom of the tank with hoses running to the top of the pump / sending unit assembly. It is probably broken around the 1/2 tank mark. When fuel level is higher than the break in the hose, everything runs fine, but once fuel level reaches under the break, the pump starts pushing fuel out of the break back into the tank and the engine does not recieve enough fuel pressure to run.
Sep 24, 2008 | 2000 Chevrolet Silverado
Garden Logo
32 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
