Question about Craftsman Convertible 25cc. Gas Line Trimmer
Craftsman line trimmer: update
Canbruce suggested a few things, which I tried (e.g., cleaning that spark plug). These helped the problem somewhat, but not significantly. Now it'll start and run for maybe 5-10 seconds, if that, and stall. Then it takes upwards of 12-15 attempts, if not more, to get another brief period of operation. Guessing it may be starved for fuel, but I have no idea what to do next. Thanks.
  • 1 more comment
  • John Barry Oct 02, 2009
    To the best of my knowledge, the fuel:oil ratio is right. As to your recommendations, I'd need extremely explicit instructions as to how to do that (I'm a novice when it comes to small 2-cycle engines), or I'd have to take it to a repair shop. Where might I find foolproof, explicit how-to directions to accomplish what you've suggested, please?
  • vince janis
    vince janis May 11, 2010
    Is your fuel to oil ratio correct, if the trimmer is old you may need to replace the fuel pump diaphram inside carb, if not old readjust fuel mixture needle valve.
  • Bruce Canfield
    Bruce Canfield May 11, 2010
    Hello, it's me again. Please refresh my memory, which is terrible, and I will see if I can add anything that will help get your trimmer running. Thanks.
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
canbruce75
  • 1776 Answers
SOURCE: Craftsman trimmer won't start
Let's start with the easy stuff first. Remove and clean the spark plug. Look into the tank and fish out the fuel filter. It should be stuck in the end of the fuel line in the tank. I usually use a short piece of coathanger with a small hook bent into the end of it. Clean or replace the fuel filter. The next thing is to clean the small screen at the exhaust. Remove any carbon build-up there that you can. Sure hope this helped and best wishes.
Posted on Aug 17, 2009
Thermo King
  • 593 Answers
SOURCE: trimmer will only run for a few secs then dies out
First, use the same oil and mix it the same from batch to batch, once you have made a batch (gallon or what ever, never add gas or oil to make more, use up the batch to the last drop, then make a new gallon). Be sure the air filter is clean, some are oil wet to catch more dirt, clean and spray it with a spray cooking oil. Next: Look for 3 adjustment screws on the carb. should be three total. 1 screw is for idle adjustment. the other 2 should be close to each other, one is low speed fuel/air mix and the other is high fuel/air mix. Adjust the low fuel/air mix screw until it will idle un-added with the throttle then adjust the idle on the throttle to get a good idle speed. Next adjust the High fuel/air mix until it gets the RPM's you want it to have. It should go from idle to high speed with out hesitation or cough. .
Posted on May 30, 2010
2strokeguy
  • 183 Answers
SOURCE: 24cc craftsman 2 stoke
Low side adjustment on the carb needs to be opened up or the carb needs to be overhauled. To open up the low sie, find the carb jet adjustment screws. The screw closest to the cylinder is the low side. Turn the screw counter-clockwise 1/2 turn. You may need to romove tho plastic locks from the adjustment screws, or if it is fairly new, you may need to buy a special tool to use on these screws. The tool is available anywhere that sells Poulan parts. If adjusting the screws doesm't fix it, the carb will need to be overhauled or replaced. Check with www.searspartsdirect.com . Replacement carbs are sometimes cheaper than an overhaul.
Posted on Aug 30, 2010
MNfisherman
  • 11896 Answers
SOURCE: I have a 25cc Sears
How about the needle and seat? Have you adjusted the air/fuel ratio to 1 1/4 turn out? How good is your intake gasket?
Posted on Sep 23, 2010
Craftsman 32cc gas trimmer ran a couple times this season, then will not start. Changed plug, new gas mix, cleaned filter and spark arrestor. No luck. Pull cord is hard to pull in the first foot or so,...
Pull the spark plug and hold the side against the engine while pulling the string. check to see if there is a spark you may need another person to help. Was the air filter oily when you cleaned it? If so you might need to remove and clean the carburetor.
Jun 07, 2011 | Craftsman Garden
Hello, I have a craftsman gas hedge trimmer that will not start. What are some things I could checl out to try to get it working
Two items fairly easy to check; the condition of the spark plug and whether the ignition coil is healthy. The plug must be removed to check it for fouling (a buildup of deposits near the spark gap) and also wipe the insulator of the plug clean and inspect it carefully for fine lines; a cracked insulator (not uncommon) will provide a path for the spark voltage to ground before it reaches the spark gap. The ignition coil can be checked by sight in a shady area (sunlight makes it tough to see). Pull the plug wire free of the plug and insert anything metallic into the female connector that will extend the contact. Position your extension near some metal part of the engine and watch this gap as you tug on the starter rope. You should be able to see the spark appear a couple of times with each pull of the rope to its limit.
These coils are not very well made and cost $30-40 US to replace.
Once you have access to the coil. use some gauge (could be a knife or screw driver blade) so you can re-gap the coil if a new one is installed.
I suggest that you go to the Sears website below and enter your model number. You should find it listed there and it will have a parts breakdown of your trimmer along with part numbers, etc.:
Sears parts dept.
Using this you can orient yourself on the innards of the trimmer.
May 31, 2011 | Craftsman 22 in Hedge Trimmer
Machine will start but won't stay running. give some gas and it runs for a couple of seconds and then dies. i did replace the spark plug but it is doing the same thing. it is a 25cc craftsman weedwacker...
I had a similar problem and it was simple to fix. I hope yours is the same. The line going into the gas tank is not far enough down in the tank.Once you prime it with the primer bulb , it will run till that gas is gone. No fuel from the tank is getting to the carburetor. If you've replaced the fuel lines recently, this may be your problem. If not, try cleaning the fuel tank and the carburetor. Hope this helps.
Sep 08, 2010 | Craftsman 25cc Gas Line Trimmer
It boggs down when i give it gas
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Craftsman 25cc Gas Line Trimmer
Aug 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Engine on Craftsman Weedwacker will not turn over.
I assume the tank has gas. The first thing to check is for spark at the plug. Remove the plug from engine, connect the plug wire to the plug and ground the side of plug to metal engine housing using pliers with plastic grip handles so you don't get a shock. Pull the starter cord and watch the plug for a spark jump. If you have spark then it is likely a gas starved situation. All these small engines should be run dry before storing in the fall of year to prevent carb from gumming up over the winter. Anyway remove the gas line and drain any gas from carb and drain tank too if it has old gas from last year. Replace fuel line and spark plug. Using new gas and 2 cycle oil, plus an ounce of STP gas treatment, refill tank. Work the primer bulb several times and pull the throttle several times, then pull cord. Keep repeating to see if you get a start.
May 16, 2009 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Feb 16, 2009 | Craftsman Garden
Craftsman Convertible 25cc. Gas Line Trimmer Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
