Question about HP LaserJet 3600n Printer
Bottom tray won't come out
The paper tray at the bottom of the printer stucked. Won't come out
  • 186 Answers
SOURCE: Hp 9130 printer
Pull out the paper tray and look where it is getting stuck to make surre there is not a small peice of paper in the path that is causing the jam. Also clean all the rubber rollers in the tray and where the tray fits in with some rubbing alcohol and a cloth. Make sure you fan the paper thoroughly before loading into the tray. The humidity causes the pages to stick together.
Posted on Jul 18, 2008
  • 3 Answers
SOURCE: hp 2015dn paper jam light on solid,won;t print
There is a manual paper release on the bottom of the paper tray. If it gets stuck the paper does not rise to be picked up. Not sure why it registers an amber paper jam for it, but I taped my release open and put the tray back in carefully. Its been working for 2 days straight now.
My real issue was I had both the low toner and paper jam lights on solid and amber. I waited a few days to post this to make sure it worked. Worth a shot for you all. post back if it works for you .
-T
Posted on Feb 27, 2009
  • 14 Answers
SOURCE: There is NO paper jam- and the paper won't feed.
hi...
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
try it out....
Posted on Apr 24, 2009
SOURCE: The bottom paper tray of
Fix for Brother mfc-440cn
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000010859&Sympt=I+am+unable+to+pull+the+paper+tray+out+of+the+Brother+machine.+What+can+I+do%3f+stuck%2c+jammed&Model=993&ProductGroup=5&Keyword=tray
Posted on May 25, 2009
  • 3278 Answers
SOURCE: When I try to print
Hello.
From the HP site:
There could a problem in the pickup assembly area of the product. There are twoblack Mylar light shields approximately 3.5 inches long. They are located onboth sides of the pickup roller under the pickup roller rod. One or both ofthese black Mylar shields can be tucked under, or partially bent when removinga paper jam from the paper input tray slot.
Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity until the fingertips reach the end of the cavity.
4. Bend fingers up to push theblack Mylar light shields back into place. The proper position of the blackMylar light shield will be flat.
5. Reconnect the power cord.
6. Print a self-test/configuration page to verify product is functioningcorrectly.
If still a problem, make sure that the tray, paper is locked in thecorrect position. Sometimes the spring in the tray can become worn out andloose. You can take that out and spread it out a little. Also, make sure thatthe tray bottom is free to move. Take out the paper and see if it goes up anddown correctly. If you don't hear the pickup roller moving or the motor runningyou may have a bad feed roller gear. There also, could be a problem with thepickup roller.
Hope this helps.
Posted on May 23, 2011
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
Paper won't come out paper light blinks
I have a similar printer. Sometimes the bottom paper tray gets stuck or caught. Make sure the printer is on a flat surface.
1. Turn off the printer.
2. Pull the paper tray all the way out.
3. Take out all the paper and then place the tray back in.
4. Turn the machine on and let it try to print without paper.
5. When the light comes on add paper hit the button and you should be good to go.
Jul 26, 2011 | Brother HL 2140 Laser Printer
We just moved, and now that I've set the printer up in a new location, the paper won't feed at all. I removed the cartridge and wipped the paper feeder with alcohol still no luck
Hi
When you move the printer normally somethings will brake and get stuck. But 1st things 1st did you check if the tray lifts to take the paper? or try to take the paper atleast? if not then you can try to wiggle the printer a little and you should fine some thing being stuck come out and the printer work well again.
PLZ RATE MY SOLUTION
Jul 06, 2011 | Samsung ML 2010 Laser Printer
The bottom paper tray won't slide out. Is there a way to force it out?
check first if there is some paper remain and clog inside before you pull it out.
May 24, 2011 | Office Equipment & Supplies
Paper light flashing when paper tray is full
Paper got stuck in my HL2030 printer I cleared it but red light keeps flashing and won t let me print.
Feb 17, 2011 | Brother HL-2030 Laser Printer
Lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Feb 21, 2009 | Lexmark X2600 InkJet Printer
HP LaserJet 3600n Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
