Question about Clarion DXZ665MP CD Player
Wiring where does the chassis ground wire connect to the adapter for a 2004 honda civic? There is a black wire on one and no black wire on the other.
  • 752 Answers
Connect it to any bare metal fram piece in the dash. Prefferably one that DEFINITELY touches the frame or body of the entire vehicle. Can also go to the wire that connects to the outer ring of the cigarette lighter.
Posted on Aug 05, 2008
I need the stock wire diagram that connects to the car stereo for a 2000 honda civic
2000 HONDA CIVIC FACTORY RADIO WIRE COLORS
BATTERY WHITE/BLUE
ACCESSORY YELLOW/RED
GROUND BLACK
ILLUMINATION RED/BLACK
LEFT FRONT SPEAKER BLUE/GREEN(+) GRAY/BLACK(-)
RIGHT FRONT SPEAKER RED/GREEN(+) BROWN/BLACK(-)
LEFT REAR SPEAKER BLUE/YELLOW(+) GRAY/WHITE(-)
RIGHT REAR SPEAKER RED/YELLOW (+) BROWN/WHITE(-)
Oct 10, 2010 | Car Audio & Video
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1988 - 1991 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1988
1989
1990
1991
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Blue/White - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Harness from Dash Indicator
Parking Lights: Red/Black - (+) Fuse Panel
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Red - (-) Driver's Kick Panel
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, 13-pin connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
1984
1985
1986
1987
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
1984, 1985:70-1388
1986, 1987:70-1720
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
License plate and trunk lights not working
check your ground side of the light circuit
Oct 13, 2009 | 2004 Honda Civic
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Metra Brand Wiring Harness: 70-1388
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Where can I get wiring diagram for 92 Honda Civic LX?
Here several documents:
Engine wiring-1992-95 Civic (except VX)
Engine wiring-1992-95 Civic VX
Chassis wiring-1992-95 Civic, 1993-95 del Sol
Good luck... remember rated this help.
Aug 19, 2009 | 1992 Honda Civic
Reverse parking light wire color coding for Honda civic 02
Check the wires with the car in reverse and the key turned on, use a meter. On cars the black is usually the ground but you need to check to be sure.
Mar 28, 2009 | 2002 Honda Civic
CDX-RA700 will not get power from my Honda Civic
Automobiles use Direct Current "DC" and is very dependant on a good ground. The black wire from your stereo should be the ground and needs to be attached to the chassis "metal part of the car". You can use an ohm meter to check for grounds by placing one lead on your door hinge (unpainted) and the other to where you are connecting your ground from the stereo. Be sure that this wire does not have voltage on it with the key off, on acc, or in the on position or you could blow a fuse or damage your equipment. Besides that make sure that you have 12v constant to the (usually red wire) and switched (voltage only with the key on) to (usually the yellow wire). Hope that helps. It's mostly about the ground.
Mar 10, 2009 | Sony CDX-RA700 CD Player
Installing a pioneer stereo in a 1995 honda civic
I'm assuming that you're connecting to a wire harness that you've purchased and not directly to the wires which were plugged into the original Honda radio.
The black ground wire from the Pioneer can be connected to the ground wire on the car. You are correct on the blue/white remote turn-on wire as well - it can be connected to the blue power antenna with no harm. If you were installing any amps the blue/white wire would also go to their remote turn-on input.
Feb 21, 2008 | Car Audio & Video
Clarion DXZ665MP CD Player Logo
90 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
