Question about Sony KDF-E42A10 42 in. LCD Television
TV comes on then the screen will go blank while sound remains fine. It sometimes goes blank/black after a few minutes, sometimes it takes an hour. The green power light remains on and steady the whole time.
  • snizzleme200 Sep 25, 2009
    I'm am not an expert at repair and won't be able to do any soldering, or working on puffed up capacitators....
  • Sony Master
  • 19,396 Answers
If the screen goes suddenly dark, and the backlight turns off, then you have a faulty inverter board. The inverter must be tested and eventually replaced.
If instead the screen stays for a while white, with backlight but no picture, then it is usually a bad digital controller board.
Test also the TV with no devices connected, eventually only with a DVD unit, and try unplugging power cord for ten or twenty minutes.
Posted on Sep 25, 2009
  • Sony Master
  • 5,138 Answers
I would pull back resolder tuner and power board also look for any puffed up capacitors near heat sinks 1000uf 16v, if no bad caps then most of the time resoldering corrects problem.
New power supply board and screen goes black
It sounds that the off timer has been set to one hour. Check it.
May 29, 2013 | Philips 47PFL3704D 47 in. LCD TV
Philips 52'' hdtv 1080p while watching it looses picture but still has sound
The back light inveterate board and CCFL lamps should be checked. Check and replace the faulty component. Back light inverter can only be replaced as card basis.
Jan 30, 2013 | Philips 52 In. LCD HDTV
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Tv goes blank, sound stays on
i had an older hitachi. Same problem. It was the capacitors in the comb filter had dried out. Replaced them and it was like brand new.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KDF-E42A10 42 in. LCD Television Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
