Question about Canon PowerShot A510 Digital Camera
Do u a card to start camera - Canon PowerShot A510 Digital Camera
I have a Traveler DV5040 and need to replace the memory card I purchased a SDHC card from Aldi and was told it was suitable for this camera but when I place it in the camera the camera will not start if I...
If you look at page 18 in the manual, you will see it uses an SD card, not an SDHC - the two are the same dimensions physically, but the SD card will only hold up to 2 GB data. You will need to obtain an SD card. BTW, Aldi were possibly not the best people to ask, as their technical knowledge may be limited.
Jun 23, 2017 | Video Cameras
New Jazz DV150. Installed new batteries (tested) and SD card (tried switch in both locations). Powers on, says "Read card....", "Goodbye", powers off.
HI, I just got off the phone with a very nice man in NJ at Digitac. He walked me through a few fixes: Try a different SD card, clear SD card, put SD card in and then start camera, start camera and then put SD card in. None worked, so he said something is wrong with the camera computer and I will have to send the camera in for warranty work.
Feb 28, 2011 | Jazz DV150 Camcorder
Hi, I have got an Olympus mju 300 Digital camera, and I have bought a 2GB XD Type M+ memory card, however when I put the 2GB memory card in, it takes the camera a good 15 seconds to start up, whereas with...
There are several reasons why could happen:
1. 2GB is a lot of space compared to 16MB. The camera checks the card each time you switch it on.
2. Card is corrupt & should be reformatted.
3. Card is defective & should be replaced.
Oct 05, 2017 | Olympus MJU 300 Digital Camera
Camera message is: memory card requires formatting : I chose the option to format and camera will start formatting then stops and this message pops up:please format memory card or put in new memory card. I...
Try formatting through the computer rather than from within the camera itself. Or, just open the card on the computer, select all, then delete. There's probably a large file in there somewhere that the camera just doesn't have enough ooomphh to move out.
Hope this helps. :)
Sep 29, 2010 | Cameras
I'm missing the camera card. How do I get a
This 5MP (Megapixel) camera has 16MB built-in memory and has an SD card slot.
Your camera uses either MMC of SD memory cards.
Radio Shack, BestBuy, Fry's, Office Depot, Office Max, has them.
Start with a 1GB SD card (Don't use MMC).
A 1GB card will hold almost 500 pictures at maximum resolution (5MP).
(Fry's is lowest cost, then Best Buy)
Sep 28, 2009 | VistaQuest VQ-5015 Digital Camera
I cannot format my brand new memory card in my Kodak Easyshare.
The I would have to say bad card. Do you have another to try?
May 11, 2009 | Kodak EasyShare C360 Digital Camera
My camera is not starting up after i put a 4 gigs SDHC card need help i pull the card out but it still doesn't start
Read thre Manual- It is likely you have an oversize card.
The manual will tell you the max size card the camera will handle
Dec 31, 2008 | Mercury Electronics CyberPix S-555V...
Regarding starting on the camera
This camera is now ten years old, and will only take an SD card, with a max limit of 2GB. It cannot recognise or use a more modern SDHC card, which is what I suspect you have been trying to use.
Sep 23, 2017 | Nikon COOLPIX L4 Digital Camera
Memory card
Its an sd card right?
because if its a bigger square Compact Flash Card you could a bent pin.
I wouldnt buy another car if you have a new one and they both give the same error.
I would suggest takeing it to a repair person if there is one near where you live. I would have to see the camera myself to be able to know for sure what was wrong.
But If you can afford to then I would really suggest getting a new one before your next trip. As even if My quick fix worked or if it started working again It could start failing again in the middle of the trip.
Have you tried formatting the card?
Jun 27, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
A70 start-up problem
It could be as well a malfunction CF card. Try to use another CF card in your camera. Good luck!
Sep 26, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A510 Digital Camera Logo
14 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
