Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
My Linksys Wireless G adarter card freezes my computer
  • 6,831 Answers
Hello
If your wirless adapter freezes your system it is definitely a driver incompatibillity, thus download the latest version of the driver for your spesific os and it should work properly.
Please rate this.
Best regards
Posted on Sep 25, 2009
Linksys wirelessg 2.4 ghz broadband router hook up and runwires, willnot work wireless
The wireless card in your computer may not be configured with the Linksys wireless settings.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 21, 2012 | Linksys Wireless-G WRT54G Router
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
I have wmp300-n card. I install card (software & drivers). The wireless works fine for about 20 minutes then pc freezes up. I have tried to uninstall software that came with it and let windows run it,...
i had that problem with another adapter, then i figured out that i was having problems with another pci adapter. so if you have another pci at the same time, try unplugging it and left the wmp300n alone, it worked for me
Apr 25, 2010 | Linksys WMP300N Pre-802.11n Wireless...
I have a wireless notebook adapter for my dell lattitude c400
Make sure that you insert the card in before booting up the computer. When Windows 2000 was created PCMCIA cards weren't hot swappable. If that doesn't do the trick, check linksys.com for updated Windows 2000 dirvers.
You can still update to Windows XP as well. Some computer stores still carry it. Wireless networking is managed much better under that operating system.
Jan 04, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys locks up windows
Just a suggestion; this option may not be available under this device, or that type port: Rather than unplugging the card, go to Device Manager, find the card, and under Properties, set the device to not turn off to save power.
Or try shutting down the wireless router, then restarting it.
Jan 09, 2018 | Linksys Wireless-G WRTP54G Router
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
Linksys WPC54G Wireless-G Notebook... Problem:
Your computer locking up could be a spyware or virus program taking over your machine as soon as you get an internet connection.
Try connecting the laptop to a wired connection and see if it does the same thing.
Run some virus scans from trend micro.
If you can re-install the software for the wireless card. This might help too.
Firefox can freeze your system but highly unlikely from a fresh install.
best wishes.
Oct 31, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Dell latitude problem
Unplug card, reinstall drivers and put back card.
If system is still freezing the card may be defective.
Sep 07, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
149 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
