Upgrading I just found out my pavilion 1903 has a dvi port. For 3 years I have used the anolong port. The back of my hp tower does not have a dvi port. I want to and a dvi graphic card so I can use the dvi. I just realized this .
Posted on Jan 06, 2008
  • 243 Answers
How much are you looking to spend?
Pressume its an agp card you require?
How to connect the HDMI Cable from monitor to Computer which has no HDMI ports?
You need a purchase a new cable. I assume your HP pavilion is under 5 years old. And you should have a white DVI port in the back for a monitor. If you do have that connector, then all you need is a DVI - HDMI cable, make sure the DVI will be to the computers end and HDMI to the monitor.
for example this cable:
Dec 31, 2013 | HP Pavilion Computers & Internet
I have an HP m9000z that was previously used with a DVI cable/monitor. I only have a VGA cable/monitor and the pc doesn't access the monitor.
This PC has a VGA and a DVI ports? Are both ports on the motherboard or a Video card? Or is the VGA onboard video and DVI is a Video card? You may have to disable the DVI port to get Video to vga or enable the vga port.
Jan 13, 2018 | HP Pavilion Elite M9000z PC Desktop
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
I recently bought a used TEAC CDWE552-GB CD Burner for my old computer. I received the power cord and cable to power it up but not the cables to attach it to my computer ( HP Pavilion 4550Z ). The ports on...
Unfortunately, I don't think you can use this CD writer on the HP Pavilion 4550Z directly. The CDWE552-G is an external USB device. The HP Pavilion 4550Z doesn't have any USB ports.
There are two options that I think you could consider. 1) Get a USB card to insert into the micro-tower. It's currently easier to find PCI USB 2.0 cards, see for some examples. Before purchasing, check to make sure the card is compatible with the OS on the HP Pavilion 4550Z. It started with Windows 98. You will have to remove the Fax/modem to use that slot. (An ISA card might work but I haven't seen an ISA bus USB card in years.)
2) Take the CD writer out of the external case. The CDWE552 should use an IDE cable; just swap this CD writer for the one in the micro-tower. The HP Pavilion 4550Z should have the appropriate cables inside the tower. The original CD reader specifications indicate it was an IDE device.
I hope this helps.
Nov 29, 2017 | Computers & Internet
Does my HP PAVILION 9500 have a DVI port for me to put a DVI HDMI adapter
yes DVI port is available in dv9000. its on left side of the laptop
Feb 09, 2010 | HP Pavilion dv9000z Notebook
How can i go dvi - hd to vga to my hp a1010n tower
DVI - VGA cable adapter. One side is DVI and the other is VGA. Connect VGA side to your pc's video output and then plug the DVI cable to the other
Nov 27, 2009 | HP Pavilion a1010n (PS563AA) PC Desktop
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
F1903 not turning on with tower when restarting
Get a PCI or VGA video Card!
I'd recommend at least somethin like a
nVidia GeForce 7300 GT (256mb) Video Card
You can get one for dirt cheap on
Or your local PC store/Repair shop.
The Problem you are having is your Video Card Driver isn't the correct one, or it's got issues...
You should get a better video card.....yours might be onboard or really low-end rated.
Pre-Manufactured PCs generally ****..... I build WAY better PCs for less.
HPs ****, but not as bad as a Dell (Dell does make the best pre mf 'd Servers which is ironic!)
but the worst pre mf'd PC I've ever fixed was a GATEWAY........
Apr 19, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Can you tell me where USB port is located in HP pavilion MX75
USB ports are located on the back and also on the front on newer desktop PCs. These are on the computer tower - not the monitor as your posting is categorized. They are rectangular slots with four copper contacts inside.
Jan 30, 2009 | HP Pavilion MX75 17" CRT Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
