Question about Dell Inspiron 1100 Notebook
Display only stays visible at lowest illumination
Display only stays constantly visible at lowest illumination setting. Raising the illumination (Fn + up arrow) causes the display to disappear (the higher the setting the shorter the time span to disappear). When the display has gone, if I close the lid and re-open, the display will re-appear for a short time.
  • 591 Answers
Sounds like your display's backlight is dying. Your scfreen is in need of replacement. The higher ther brightness setting the faster it quits working.
Posted on Sep 26, 2009
List each function key
o F2 boot to BIOS.
o F12 boot device menu.
0 Fn+F1 sleep/hibernate per power management setting.
o Fn+F2 battery charger ON/OFF.
o Fn+F3 DCP Power Manager Battery Status.
o Fn+F4 numlock ON/OFF for embedded Fn+numeric keypad.
o Fn_F5 scroll lock ON/OFF.
o Fn+F7 DCP.
o Fn+F8 display device.
o Fn+D display OFF/ON (conserve battery without shutting down entire system).
o Fn+Z reset fan temperature table and sensor.
o Fn+Right-Arrow keyboard illumination OFF/ON Auto ALS (lit upon input in dim lighting)/ON (lit upon input). Use DCP to set input device, brightness, and auto OFF delay.
o Fn+Left-Arrow display Ambient Light Sensor OFF/ON (brightness varies with ambient lighting).
o Fn+Up/Dn-Arrows override display brightness until boot to BIOS setting and/or power mananagement setting.
o Alt+Fn+F11 screen shot.
Jul 09, 2014 | Dell Latitude E6400 Notebook
We have brand new Viewsonic PJL7211 Projectors at the high school that I work at, and they are fantastic machines, however the projector cannot find our HP laptops and so we have to spend mintues...
I dont believe so Sir/madam, my advice would be to configure the settings in order to make them default to connect. That way you should be able to skip the hastle.
Mar 04, 2011 | Computers & Internet
Weak or non-existent illumination of viewfinder information
sending the faulty electronic camera back to seller (eBay) thank you George Birrell
Apr 18, 2009 | Contax RTS III 35mm SLR Camera
Fn+F5 toggle not working
Using the "easy mode" that the computer boots to:
- go to the SETTINGS tab
- then select DESKTOP MODE
your external monitor may not be able to display the
higher resolutions available from the eeepc.
- change the selection from AUTO to MANUAL
then set it to the lowest resolution
- if that works, then increase resolution until you
find the limits of your external monitor.
if you have another monitor available, try it.
you said "like it did before" before what?
have you changed anything else?
Apr 06, 2009 | ASUS Eee PC 900 Notebook
Cursor Will Not Stay Put
Try uninstalling the drivers from the device manager, then do a hardware search. It will automatically find the touch pad and reinstall the drivers. If this doesn't work, then check the connector under the keyboard. Disconnect it and reconnect it, they sometimes work loose. If these don't correct the problem, then you have a faulty touch pad and you'll have to replace it.
Jun 20, 2008 | Toshiba Satellite A45-S250 Notebook
Display illumination
go to the manufacturers website for your laptop and look for the Support Tab or menu.. click on it and look for Driver Downloads or similar.. then Download all Vista compatable drivers available..
Jun 04, 2008 | Sony VAIO VGN-N130G/W Notebook
Hp laptop
when u switched on the computer,screen will be Black then That is in RAM problem.Better to u change it RAM and check it.
Feb 28, 2008 | Computers & Internet
My lcd display turns off randomly
check power saving settings under control panel
Dec 01, 2007 | Acer Aspire 9300 Notebook
How do i connect my laptop
Assuming that the laptop is hooked up to the projection TV using the correct cables or connectors and still no video display on the TV, perhaps you need to lower down the laptops screen resolution first using your laptop's screen display before pressing the Fn + F? key.
To lower the screen resolution, right click on any clear area of your desktop, select Properties. click on the Settings tab, move cursor of Screen resolution to farthest left, Apply, Color Quality to lowest, Apply. Additionally, click on the Advanced button, Monitor tab, select lowest Screen refresh rate.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Dell Inspiron 1100 Notebook Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
