Question about Microsoft Windows XP Home Edition
Everytime i try to open an application or anything, it says the file "rundll32.exe" is not a win32 file, how do i change
  • 729 Answers
Hi hansomeone45
Maybe you have virus on your computer, and it has infected the file rundll32.exe and therefore you cannot use it.
You can try several things I explain here :
IF you have a backup copy of your hard disc´s you can restore from the backup copy.
You can try to system restore in at the : start- all programs- accessories- system accessories- system restore
or in : start- help and support- and there find "system restore"
System restore will roll back the computer as it was before (day, week, month ago).
You can reinstall the computer for the procedure please look here :
http://support.microsoft.com/kb/315341
You can read about the file here :
http://en.kioskea.net/contents/processus/rundll32-exe.php3
Or you can try to run this app :
http://www.rundll-exe.com/
OR
http://www.goarticles.com/cgi-bin/showa.cgi?C=1945037
Remember you can try to copy the file from another computer to your computer !
Hope that helps
Have a nice weekend
Please rate my answer
Posted on Sep 25, 2009
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Apr 20, 2014 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Windows cannot find rundll32.exe
Are you getting a window that pops up asking you to select which program to open with when you click on anything? If so your program file associations have been changed by a virus or infection.
Try restoring them by running the programs from the link below. Run each one of them. Don't worry, they are safe, tried and tested many times to get things back in order.
http://www.dougknox.com/xp/file_assoc.htm
Apr 18, 2012 | Acer TravelMate 5740-6529 - Core i5 430M...
How would i fix with my icon default,, everytime i open an application... open in suggested file... i want to return it to default... application,, and my rundll32 is not working, system32
***Find a copy of rundll32.exe in folder c:\windows\system32\dllcache or in c:\windows\servicepackfiles\i386.
If you find this, go ahead and copy rundll32.exe to the system folder c\windows\system32.
Otherwise you need a windows disc to expand this file (see below).***
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
Jan 25, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have a pc dell xp windows and everytime i try to do something or download something it comes up rundll32.exe unknown file associated with its everytime i go to a web site that says it will fix it i...
You definitley have a virus/malware issue. This is not unusual with rundll32.exe files. rundll32.exe is a legitimate and needed file within Windows. The key is "unknown file associated" which is an indication that a new file with similar name has been inserted onto your PC.
My suggestion would be to boot into safe mode without networking and run your anti-virus software as Administrator.
Sep 28, 2009 | Dell Inspiron 8600 Notebook
How to fix rundll32.exe-Application Error The instruction at "0x009a068f" referenced memory at ''0x009a068f''.The memory could not be ''written''.Click on OK to terminate the program Click on...
It all depends on where the file is located.
The rundll32.exe file is located in the folder C:\Windows\System32 is a system file . In other cases, rundll32.exe is a virus, spyware, trojan or worm! .
Jun 04, 2009 | Computers & Internet
Error: "The application cannot be run in win32 mode"
Open my system, click mycomputer and then opening only c drive, but D,E,F drives are not opening, if telling application cannot be run in win32 mode ( how can i solve the problems.)
Jan 07, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Home Edition Logo
852 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
