No Power Hi i have this I-Star monitor it was working fine, now i just have no power at all? where could i start Plz? Istar, model n17s
    Problem Solver:
  • 11 Answers
Turn off the monitor (and for safety the pc). Unplug the monitor from the PC. check the cable and the port for dust or particles. Check the whole cable from end to end for any tearing of the sheeth. Have any pets that like to chew things by chance? This may help us get started. If you blow on the cable end and the port on the PC, that may due the trick. It may also release any static charge that could have built up.
Posted on Dec 17, 2007
I have a Star Logic LCD monitor. Recently I have been having a problem powering the monitor on. Sometimes when I press the power button or bring it out of hibernation, the screen remains black and the...
First place to check will be the DC filter caps in the power supply section. See example of failed monitors due to bad caps here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 10, 2010 | Star Logic 17" LCD Monitor
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
How to connect a maglock to a fire relay? I have to insure that maglock controlled doors release when the fire alarm is activated. I have a Ccure Istar panel and I think a apc pwr supply
On most fire alarm panels there are normally open and normally closed relays that will change state in the event of a fire. The negative power line can be ran through these relays to allow the maglock to be powered down in the event of a fire. The relay on the fire panel may need to be programmed to do this or it may come programmed by default which is usually the case. Hope this helps.
Sep 25, 2009 | I-Star PSU ISTAR|TC-550PA RETAIL (TC550PA)...
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
Mar 21, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Power on/off
Hi, Try using another outlet.
Does your AC power cord have any indicator lights which is why you know the power cable works fine?
Base on your assessment, I would say the power supply board on the monitor needs to be replaced.
Thanks,
Mike H.
Nov 02, 2008 | Acer AL1717 17" LCD Monitor
Moniter is not displayed energy star not came on
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
Aug 02, 2008 | Gateway FPD1975W 19" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
Monitor failure
Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Monitor keeps blank even the power lLED is on green
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Computers & Internet Logo
391 people viewed this question
David Payne
David Payne
