Question about Cobra 18 WX ST 40-Channels Base CB Radio
Will a bad mic prevent audio? - Cobra 18 WX ST 40-Channels Base CB Radio
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
Yes, a bad mic can prevent audio from being heard through the unit.
Posted on Sep 25, 2009
Testimonial: "Right on the money! I appriciate your quick response, I have no other mic to try so I just wanted to varify before I buy. "
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Jul 08, 2015 | Motorola Radio Communications
Vertex 2200 transmits but makes no sound
You mean NO Audio Transmit?
If there is No Audio at PTT Bad MIc Cord.
Change the Mic cord.
Dec 01, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
NOT RECEVING OR TRANSMITING
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
Jan 04, 2013 | Radio Communications
Hello, I have logitech P.C. spekers on my desk which is situated in a recess , and I use them with my webcam however the interference does not allow me to speak to the other person it's so bad is...
Yes, if it's an enclosed space they create reverberence, drowning the microphone. You will have to locate them completely differently or use headphones when talking.
May 09, 2011 | Logitech LS11 2 Speakers
Dont have any rx sound
check your antenna, coax, and all connections.
Make sure if you have an RF gain it is all the way up. make sure squelch is not to high.
If that doesn't help, your mic may be bad. If you have a bad mic, you will get no audio. If no mic, no audio. try a new mic if the first steps do not help.
Mar 02, 2010 | Radio Communications
My mic keeps getting this popping noise wen i record, i have a pop filter an it's not a wind noise it's a crackling sound
Is it a condenser mic? Either your mic is bad or you need to add a compresser to your signal path...
Feb 09, 2010 | Audio Technica Audio-Technica AT2020...
Webcam recorded audio have interferance
make sure you only use 1 mic .if that dont work try pluging in a diff mic. most laptops have built in mic's it might be bad disable it in control panel and use new mic
Oct 07, 2009 | Toshiba Satellite A135-S2386 Notebook
Dell C521 Mic input permanently connected to Audio out put
Control Panel > Sounds and Audio Devices > Voice (tab) > Voice playback > Volume Button > Advanced Button > PC Spk Mute check box
Apr 15, 2009 | Dell Dimension C521 PC Desktop
Tape loop
You may need to purchase a cheap external mixer with both mic and line inputs, and use that to mix the mic with the DVD audio. In most receivers, you can only select one input at a time. The output of the mixer can then be plugged into any spare receiver input, such as AUX, CD, DVD, etc. When not using Karaoke, you can simply turn the mic input down to prevent it from interfering with the DVD signal, but will still need to have the mixer on to hear DVD's.
Jun 26, 2008 | Onkyo TX-DS797 Receiver
Cobra 18 WX ST 40-Channels Base CB Radio Logo
122 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
