Question about Dell Latitude D600 Notebook
It wont charge using the ac adapter. its not the adapter because we've gotten two others and the computer still wont charge
    Novelist:
  • 137 Answers
In this case..since you hvae already tried couple of adapters they are not wokring.. check to see if you giggle around the cable if it works. if doesn't then motherboard needs to be repalced.
Posted on Sep 25, 2009
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
Coolpix s3000 wont charge from car usb adapter?
The battery in this camera has to be removed and connect to an AC adapter to be charged.
  • Rechargeable Li-ion Battery EN-EL10
  • Charging AC Adapter EH-68P
May 15, 2012 | Nikon Coolpix S3000 Digital Camera
How do i charg my dell dj if i dont have the ac adapter and all i have is the usb?
If you've let the charge fall below 25% then the only way to recharge it is with your AC Adapter.
If it's above 25% then you can recharge it with your USB Cable connected to your computer.
Jun 21, 2011 | Dell DJ MP3 Player
Laptop power charging stops and laptop later shuts down and no charging
First you should figure out what caused this problem. Here below are some possible cause:
AC Adapter Problems
If the AC adapter is not working properly, then the charging won't occur at all. An AC adapter, with lower than required voltage settings, will not be able to charge the battery. See to it that the AC adapter matches the laptop battery's requisite settings. A loose wire or internal breakdown, may render an AC adapter useless. Changing the adapter all together might solve your problem.
Acer Aspire 5720 AC Adapter
Power Management Software Problem
Sometimes, the problem is merely with the power management software. This is the classic case, when the laptop charges when switched off, but doesn't when the computer has booted. The software may have gotten corrupted which must be causing the problem. In such a case, go to the device manager section and uninstall the power management software. In case of Windows XP, uninstall 'Microsoft ACPI Compliant Control Method Battery listing' from the device manger section. Take care that you do not install any other AC adapter driver software. Then go for a 'hardware scan', which will automatically identify the battery and reinstall the latest version of the drivers again. That will restore the charging facility of your laptop.
Internal Charging Circuitry Problem
If neither the AC adapter, nor the power management software has a problem, then problem can be with the internal charging circuitry of the laptop. In this case, there is little you can do, other than send the laptop to the manufacturer's service center.
Bad Battery
If you have checked for all of the above, one of the main reasons, which could lead to the problem of laptop plugged in but laptop battery not charging is a bad or dead battery. Run a laptop battery test. If your laptop is quite old, this could be one of the most likely reasons. Get the battery checked from the manufacturer and check if it has exceeded its predicted recharge cycle limit. It is important that you get the dead battery replaced immediately with a new one. Laptop battery troubleshooting will solve the problem.
Hope this will help.
May 09, 2011 | Acer Aspire 5720-4230 Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My Dell inspiron 9400 wont charged my battery. Both the charger and battery are new
try to charge the battery while the computer is off for 3 hours. if that does not work, remove the battery from the computer and turn on the computer using only the ac adapter. if the computer is working fine using only the ac adapter, call your computer manufacturer for possible battery replacement
Jun 11, 2010 | Dell Inspiron 9400 Notebook
New AC Adapter Will Not Charge Battery/Operate Computer
Most probably static electricity killed some circuitry inside your laptop.
Nov 12, 2009 | Acer Aspire 3610 Notebook
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
54 people viewed this question
Alun Cox
