Slow fill, takes a long time to fill up - Washing Machines
    President:
  • 1,776 Answers
Check the water inlet valve. If there is a problem it can cause a slow fill condition. Unplug the machine, turn off the water and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. A lack of continuity means a bad solenoid and the valve assy will need replaced. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 25, 2009
Why my uberhaus dual flush toilet does not flush properly
Perhaps it is taking a long time to fill the cistern, take top off and see if it's filling after flushing, if it's slow and pressure is ok it is likely to need a new diaphragm in the filling valve.
May 12, 2014 | Home
How to fill the bobbin
Please first up on needle bar (Pressre foot). Then take one small screw driver or big needle put on bobbin center before some 3 or 6 times wring some thread ,then put on the bobbin machine wheel side after machine start slow and correctly you fill the bobbin.
Dec 27, 2013 | Sewing Machines
We just bought the washer and now it will stay on for 5 mins then all buttons blink and it says LF
LF stands for long fill,if it takes longer than a preset time by the machine it will go to LF,check water fill hoses for kinks,plugging that will slow down water fill time
Sep 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not fill up with water before starting, it takes about 3-4 times brfore unit will run with full amount of water. loads take forever.
dish washers have a fill valve. the water supply line most likly has a net like filter that is stoped up with trash. Or fill valve is bad.
same thing happens to washing mashines. when they start filling up very slow you will TURN OFF water supply and diconect hose, look inside and there is the problem.
May 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water fills slowing in washing machine, kenmore ultra fabric care
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
03 A4 Audi - Gas fill up takes a long slow time
sounds like the filler pipe is damaged or a piece of rag or something stuck down the pipe .
Jul 02, 2009 | 2004 Audi A4
2004 Ford Taurus takes 15 min plus to fill fuel tank, help!
theres a problem with the pipe that goes from the gas tank to the gas cap.Look under neath and see if the hose is pinched or bent.Another cause could be who ever owned it before had the tank out and they messed up the hose when they put it back in but that is differently the problem..
Apr 01, 2009 | 2004 Ford Taurus
Won't take gas
don't insert nozzle in fill hole so deep. It is not getting the air it needs to vent out while your fillinh the tank. Also start off slow on filling the tank, so that the air will start coming out while gas is going into your gas tank. like is said, the tank isnot venting fast enough, to let the gas come into the tank.
Jan 31, 2009 | 2002 Mazda Protege
Very slow output to fill cup
You will need to Descale the Machines. Most likely calcium bulidup inside machine.
Jan 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
