Question about HP PSC 1410 All-In-One InkJet Printer
Printer cartridge Problems
The printer keeps saying there is a problem with the printer cartridges. We've tried removing them & new cartridges. We cant do anything else because it won't let us.
  • 116 Answers
SOURCE: PROBLEMS REPLACING BLACK (21) Ink Cartridge
try cleaning the circuit of the cartridge and the printer with a tissue paper.or you have to replace the cartridge and have to buy genuine hp cartridge.as the non hp is not getting detected because the circuit is faulty in that non hp cartridge.ask the shopkeeper to replace the cartridge with another same non hp cartridge.he should give you the another replacement cartridge as his cartridge is faulty.or tell him to get checked that non hp cartridge in other f380 printer if he would be having.and if the cartridge is working in another printer there is a problem in printer.
but as per my knowledge and experience its because there is dust either on the cartridge or on the printers circuit where u install the cartridge.try cleaning the contacts gently.it should work.
Posted on Oct 05, 2008
rizla
  • 1463 Answers
SOURCE: Printer says Remove and check colour cartridge
hi john
see if any on there site helps yo here theres also a manual on here as well.
Ink cartridge or toner, paper & accessories HP Photosmart C4183 All-in-One Printer
riz.
Posted on Jan 20, 2009
  • 8 Answers
SOURCE: 4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
kriegersugar@yahoo.com
Posted on Mar 14, 2009
  • 240 Answers
SOURCE: hp officejet 4215 all-in-one printer screen says remove and check
try to shut it off and up it again...
other solution..
clean the tab circuit of the printer where the cartridge is installed...and also clean the tab circuit of the cartrdge...
warning before opening the printer please shut it off...
to avoid injuries,,,,,^_^
Posted on May 12, 2009
  • 240 Answers
SOURCE: printer shows remove and check print...
maybe it suffered loss connection between the printer and the printhead just try to clean it..with alcohol..or maybe you print cartridge has in it's low ink state..
Posted on May 18, 2009
I need Help fixing my HP Officejet 4215 All in One it keeps saying Cartridge Error and wont let me print anything.
Try reinstalling the printer drivers and software and plug connecting to the pc too
If problem still persist
There may be a problem in the cartridges holder
Then you have to connect with the customer care of the printer.
Or have to buy new printer easily and cheap at ebay
Aug 29, 2015 | HP OfficeJet 4215 All-In-One InkJet...
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
I just put a new black ink cartridge into my printer and now it says error with alignment I've reinserted the cartridge several time and it says the same thing everytime. What do I need to do? and...
Make sure you are inserting the correct version of black cartridge for your model. Try to remove both cartridges from the printer. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert your cartridges. You can also try to insert a different known working black cartridge to determine if the other is faulty.
Jun 26, 2011 | Lexmark X6170 All-In-One InkJet Printer
Printer keeps saying remove cartridge on the right
i have this problem to.. will try to reset it and resend
Mar 29, 2010 | HP PhotoSmart C4180 All-in-One Color...
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
My 7410 keeps saying to add a black ink cartridge but i did
Remove black cartridge and check to insure the spring has not broken loose.
Jan 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Replacing the ink cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
3940 blinks and cant pritn
hello lotsaprint, ipang
Few days ago i had the same problem with my hp 3920 color photo printer. All i did is removed the cartridges one by one and the problem was solved. Try removing the color cartridge first, then switch on the printer see i the problem is solved the cartridge contacts must be dirty. clean it with soft tissue (dont use any liquid) and reinsert the cartridge. If the problem persists u may need to replace the cartridge. Check with a new one if u can borrow one from anyone b4 u buy.
Repeat the same procedure with black cartridge if necessary. If u r new and need guidance for removing the cartridge, then do the following.
1). Switch on the printer.
2). Open the front cover. The cartridge will now move to the
center.
3). Switch off the printer and remove the power cord.
4). push the cartridge gently downwards to detach.
Close the cover when u r done with above mentioned.
For more info see the user guide u go with the printer.
Hope this was helpful
anishpillai2
May 05, 2009 | HP DeskJet 3940 InkJet Photo Printer
Problem with printer
Have you tried a new magenta cartidge. I think it has run out, that'swhy you can only print black
Mar 23, 2009 | Canon imageRUNNER C3200 Color Printer
HP PSC 1410 All-In-One InkJet Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
