Question about Microsoft Office Professional 2007 Full Version for PC
Key thats works
QDB9R-BXVJ2-4YPXD-2H792-VM7Q8
    President:
  • 1,015 Answers
You should never post your product key on the web. Are you looking for a key that works or is that a valid key? If you need a key you will have to contact microsoft or whoever you purchased the software from.
Posted on Sep 25, 2009
My 96 Ford Taurus anti-theft light flashes in the morning. Car will crank over revs will go up then car will stop. After a hour or two it starts then goes very good all day until I go to start it the next...
Your key is failing, hence the flashing THEFT lamp.
If you have a backup key at home, try that one. If it works, and you can get a moment where your 1st key is in the mood to work, you can buy a new key from a locksmith and add it yourself, then throw away the bad key.
There are several variations of THEFT system, and the procedures are similar. Oldest and easiest requires 1 working key in hand to set the car up and allow you to add a new key. The next version requires 2 working keys, but the procedure is the same.
Insert 1 key, or one of of your 2 working keys, turn to run, then remove. within 5 seconds, insert the other key, turn to run, then remove, NOW insert the NEW key, turn to run and watch the THEFT lamp. After 3-5 seconds the lamp should turn OFF. If it does, the new key is accepted and programmed. Throw away the bad key as it will simply become a problem and you cant trust it and the thought someday it might work will simply strand you one day.
If you DONT have a working spare, go buy 2 keys anyway matched to your broken key. You will need 2. If your car is the earliest version (available in 96) you MAY be able to add new keys with 1 working key and your current key works sometimes you say.
Do the above with your 1 old key or with 2 if you have a spare, try the 2 new keys one at a time and see if the theft lamp will turn off. If that fails, you wont lose anything, the new keys are still good, but must be programmed with a scantool. Any good repair shop that can handle programming for FORD will be able to do it. The tools that can do it are fairly common nowadays.
Mar 07, 2015 | Ford Cars & Trucks
Why my dell vastro both ctrl keys not working?
Go to a document and select some text. Hold down the Ctrl key and press C. Go to a blank document and hold down the Ctrl key and press V.
Did that work?
May 14, 2014 | Dell Computers & Internet
Keyless remote will not respond to my 2004 ford expedition
try replacing the battery in it first. If that doesn't work and you have another key fob that is working correctly, cycle the key from off to key on engine off 8 times till you hear the doors lock and unlock. Then press a button on the key fob that works and then the one that does and cycle the key off and it should be re-programmed. If this doesn't work you may need to replace the key fob.
Apr 12, 2014 | 2004 Ford Expedition
My fn key wont work on toshiba sattelite pro
FN (Function Key) that is usually located near the bottom left on the keyboard is not a key that you press by itself to do anything. The FN key works in combination with the (F1 thru F12) and any other key that has the same symbol or color as the FN Key. You have to Press and HOLD the FN key while pressing another key.
If the FN key is Blue and for example your F8 key has a (white F8 on it and a Blue battery icon on it) then to see your battery metor (how much charge it has left) you would Press the FN and hold it then press the F8 key. The F8 that is white does not require you to press the Blue FN.
Sometimes the FN key might have a white square on it, then the keys that work with the FN key will also have a symbol with a white square around it.
Mar 25, 2012 | Toshiba Sattelite® Pro A200 PC Desktop
How can i get my fn key to work
I don't have a product key for my microsoft office professtional 2007.
FixYa and it's experts do not provide product keys, serial numbers, illegal software, authorization numbers or codes, warez, hacks or cracks under any circumstances. Any expert that does so will be barred from answering questions. Those asking are subject to their membership being deleted and be barred from the site.
Fixya will not provide a serial number, it is violated the rules of piracy.
Piracy is not allowed,
Thanks for using fixya
Regards
PCmania
Jun 10, 2010 | Compaq Armada M700 Notebook
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Key Does not Work.
Ok, If it is the Factory Key, It should have the Plastic Finger grip at the Top. This Finger Grip has a Transponder Chip inside that Tells the Ignition that the Key is the Correct Key for this car, Go ahead and Start. These Transponders do Stop working Sometimes. If you will take the Key to the Dealer they can Reprogram the Key to work for you. But, It has to be the Factory key for this. If you have had a Key made, The key will not have the Chip inside it and will only work on the Doors. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 28, 2009 | 2005 Ford Taurus
Shift key has to be pressed firmly to work.
If there were more that one key that has failed it would indicate that you have a keyboard controller chip that has failed or that the connector from the keyboard to the motherboard is not making proper contact. You may get that key to work by pressing that key very firmly.
You may be able to fix the faulty key by removing that key and spraying the faulty key contact with electronic spray cleaner whilst pressing the key pad several times. It may not work because it may be sealed and the cleaning fluid may not be able to penetrate the key contacts.
Then the only thing to do is to buy and fit a new keyboard from the manufacrurer.,
Nov 26, 2008 | Balance CN6555 Notebook
Microsoft Office Professional 2007 Full Version for PC Logo
135 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
