Question about Dell InspironTM 1501 Notebook
Screen is black on startup but desktop is barely visible in background, everything appears normal when I connect to a separate monitor.
  • 11,896 Answers
Go to control panel, and then display. Check that all drivers are updated and change display settings if needed. Last possibility is a bad bulb in the screen
Posted on Sep 25, 2009
Testimonial: "Thank you - I don't know how to check the bulb, but this is something to look into."
    Problem Solver:
  • 34 Answers
This is usually a probllem with a bad inverter, which provides the energy transfer to the LCD screen to make it light up. It is possible that the LCD is starting to go bad, or the cable to the monitor, but most likely it's an inverter, as it's a common culprit. You can find many "How to " articles on the Web to fix this common problem.
Posted on Sep 26, 2009
    President:
  • 1,187 Answers
The screen is lit up by a fluorescent lamp and the lamp is powered by an inverter circuit.
You can open the laptop keyboard bezel and try to re-seat the screen cable.
If that doesn't work, and you are brave, then whack the screen (seriously) gently and it may start working.
Fixing it may be a bit costly...
I have a Dell Studio one desktop and monitor goes off after 2-3 seconds on startup
Wow, now that's why I don't like all in one's on anything. If one thing breaks down, you're out of all the others. OK, it sounds like your video is bad or going bad. Now if you had a regular computer it would be easy to track down the problem because all you would have to do is plug an external monitor into the computer and see if it does the same thing. I'm not sure if your all in one will allow you to attach another monitor, if it does, do it. If it does not, then you've got to suffer the consequences of an all in one and that means being without everything until the one thing is fixed.
Mar 29, 2012 | Dell Studio One 19 PC Desktop
When I turn the computor on the monitor is working okay. But as soon as I enter mt password, the monitor screen goes black but the icons are still clearly visible
the problem will mostly be a background desktop issue.change the desktop background and you should be having a normal screen again.
May 04, 2011 | HP w1907 LCD Monitor
I have a Samsung syncmaster 933bw 19 inch LCD monitor. It use to work but for some reason it stopped. When I turn it on, it comes on normal and shows the background of the desktop for about 2 seconds and...
hi, try to open the monitor back cover, then look at some of the capacitors in power supply modules if anything looks normal maybe the problem on it are the socket of the flex,
try to unplug aligned and plug it back.
hope this will help......thanks
Jun 18, 2017 | Computers & Internet
DIM BACKLIGHT TOSHIBA L305D-S5924 LAPTOP
There are also another reason , the Back light lamp might be damaged also!
May 11, 2010 | Toshiba Satellite L305D-S5895 Notebook
Screen is dim barely can see desktop in background
Usually this is a problem with the backlight, or inverter. Most of the time the inverter is the problem which is a pretty cheap fix. If its the backlight, then you will have to replace the lcd, which is much more expensive.
Normally this is caused by the power inverter for the lcd2.gif. It is a small circuit board right below the lcd, that powers the backlight. If you take off the front bezel of the laptop you should be able to see it, it will have a 2 wire power cord coming out the one end, and another plug in2.gif on the other end with several wires.
Check ebay for a replacment but make sure you get an identical model as the one you have, as they are very specific to each laptop. The inverter will have the part number written on it.
Sep 11, 2009 | Acer 22" X223w LCD Monitor
My comouter screen has changed colour and is barely readable, the startup when it says 'DELL is a white background and orange text anf then when i choose what user i want to go it almost like an...
If it is still under warranty call dell asap. Normally that is the LCD going bad or the video card, which is built in on the motherboard. Usually there is nothing a home user can do with this problem. LCD's are not too hard to change but the Motherboards can be a real bear.
Aug 09, 2009 | Dell Computers & Internet
Dell E152FP monitor goes black at startup, but not permanently
My bet is that your monitor is on it's way out. If this is true, it will get worse until it gets to a point where it no longer works at all. Connecting the monitor to another computer should confirm my suspicion. The monitor has probably developed a problem with some capacitors inside. The parts are not expensive, but finding a shop to do the work at all may be a challenge. If you're handy with a soldering iron you might want to have a try at it.
Jun 13, 2009 | HP W2007 LCD Monitor
Compaq NX7010 Display problem
Sounds like either the LCD or the inverter to the LCD is going bad you on. After it heats up thats when the problem starts. If your laptop is under warranty I would call HP Tech Support and let them troubleshoot with you over the phone either way they will probably replace the LCD and inverter.
Feb 28, 2009 | Compaq Computers & Internet
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Dell InspironTM 1501 Notebook Logo
106 people viewed this question
Alun Cox
