Question about eMachines T3393 PC Desktop
Plug me sd card flash reader into my emahines desktop. after 5 minutes of looking searching for the "F drive" removable disk. I get error message I/O device not working.
  • Mihajlo Jerkovic May 11, 2010
    where do u plug it in and r u using on-board card reader or do u use usb card reader. where do u plug it in if it is usb ie.. front usb or back?
  • 145 Answers
GO THREW THE USB PORT THAT HOW I DID TI
Posted on Jan 08, 2010
My handphone cant read sandisk micro sd.. how to recover it?
You can connect the sd card to computer with a card reader, then you can follow this sd card recovery guide to recover your files
SD Card data recovery guide
After you get back your files, you can format the card and try to use it on phone.
Jan 26, 2013 | SanDisk 2GB microSD Memory Card
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
Toshiba flash cards not working
Flash Drive or SD Cards? Flash Drive is where you put the mechanism into a USB Port. SD Cards are where you might take the card out of a camera and stick it into the SD Card Reader Slot on the computer.
Which one are you saying is not working? If its the SD Card Reader, go download and reinstall the driver again.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Card Reader drivers.If all fails maybe your card reader has gone bad. You can always purchase one for under $10 that plugs into the USB Port. When the site below comes up just type: SD Card Reader in the white search box and hit GO. The link is below:
http://www.tigerdirect.com
Apr 21, 2012 | Toshiba Computers & Internet
Where can you use a sd card on a dell inspiron 530
The 530 doesn't have a built in port for the card but you could find one at www.surpluscomputers.com that will read multiple types of cards. Have you tried plugging a USB cable from the camera to the computer and downloaded the info that way?
Dec 05, 2010 | Dell Inspiron 530 Desktop Computer
How can i download a music from computer to my memory card using my card reader,help please
1. First insert your SD card in the card reader.
2. Plug the card reader to your PC.
3. Go to My Computer, you will see the SD card as removable drive.
4. Double click in your card, and open.
5. Again go to my computer, open the a separate window. Open the folder containing your music files.
6. Select the required music file, right click, in the pop up window select copy.
6. Go to your SD card window, right click, in the pop up window select Paste.
7. You will see a window showing coping in progress.
8. After completed the process close the window.
9. Look at the right side of the task bar, there will be an icon, Safety remove hardware, left click, in the pop up menu select your SD card drive, one notification will come, "its safe to remove the hardware"
10. Remove the Card reader from your PC.
Aug 18, 2010 | SanDisk 2GB microSD Memory Card
SanDisk 2.0GB disk full - but it's not full!
1. Right click My Computer and select Manage.
2. Open the Device Manager and find your USB drive under the Disk Drives heading.
3. Right click the drive and select Properties.
4. Choose Policies tab and select the "Optimize for performance" option.
Click OK.
6. Open My Computer.
7. Select Format on the flash drive.
Hurrah there is NTFS option available now
8. Choose NTFS in the File System dropdown box.
9. Device Formatting is completed.
Important: To remove a device safely without data loss use a "safely remove hardware" procedure or Eject function from Windows Explorer.
Apr 04, 2009 | Electronics - Others
Error message
"UPDATE - summary added, history moved to end: This problem seems to be caused either by malware (virus or spyware etc), or by software following a Windows update or some other software installation or uninstallation (particularly HP, Norton or QuickTime software) trying to check for removable media that isn't there (e.g. disc in DVD drive or card in card reader), when it shouldn't be doing that check."
source: http://www.consumingexperience.com/2007/11/windows-no-disk-exception-processing.html
another tip try running "search and destroy"
Dec 31, 2008 | Dell Dimension 4500S PC Desktop
How do u format sandisk microsd 2gb and microsdhc 4gb disks
You can only form sd Hc if your card reader is approved for SDHC use. It should tell you that on the outside of the card reader or in the documentation of the card reader.
If your drive isn't formatting 2gb, it could be that the driver was designed prior to 2gb cards being released. You could look for a new driver or replace it with a card reader that supports SD HC use as will as a 2 gb SD drive.
Nov 12, 2008 | SanDisk 2GB microSD Memory Card
Micro sd
let me understand this...to erase from it, just pull it up after going to my computer and finding the usb port it is in and delete anything that is on it....
now you 2gb memory/card/stick is new? is this a memory card for your camera?
If your sd card is plugged in to removable disk k and you send your photos to it, then they should be on there. That is all you have to do is select, send to and choose disk K.
if you want to make sure they are going there, have disk K open and running at the bottom, it will not hurt a thing.
Hope this helps
Feb 12, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
eMachines T3393 PC Desktop Logo
70 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
