Question about Leica Digilux 2 Digital Camera
I own a Leica Digilux 2 Camera. I am unable to take pictures. A blinking red dot and red box appear on the viewfinder. Thanks
4 Suggested Answers
SOURCE: Leica Digilux 2
Thanks for the response! I actually sent my camera in a month ago and they promised to fix it for free...although it's a 4 month turn-around time. Still, better than buying a new camera!
Posted on Mar 15, 2008
  • 241 Answers
SOURCE: My Leica Digilux 2, recently purchased and never
Does the menu in the camera work?
You may need to activate some Postview function in the menu. If the camera takes pictures, you should be able to view them in playback mode. There could also be a Preview mode, which requires pressing OK before storing pictures. Preview/Postview should cancel each other though...
Posted on Apr 13, 2010
ssemul
  • 202 Answers
SOURCE: I own a Leica DIGILUX
there is problem with key switches may be there is some due or some water drop goes in side. check by opening your camera if you find then clean it.see what hapen if still problem need to replace key switches.
Posted on Oct 18, 2010
Testimonial: "Amazingly Prompt helpful particularly regarding Leica cameras as there are not many authorised service centres in India. Thanks. SK Pillai"
I have a Leica Digilux, but could not fine it anywhere on tghe dealer spots. I need a memory card for it and its difficult to get locally. The size is larger than the regular cameras.
Amazon could be a help:
http://www.amazon.com/MEMORY-Leica-DIGILUX-Digital-Camera/dp/B000Y06WXA
It may depend on what your exact camera model is. You have only stated Leica Digilux.
There is the Leica Digilux 1, Leica Digilux 2, Leica Digilux 3, Leica Digilux 4, and the Leica Digilux 5. Most seem to take the SD HC (the SD card may work as well) card:
http://www.google.com/search?q=Leica+Digilux+memory+card&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=FjQaTtGBMoKusAKnxLzCBw&ved=0CDsQrQQ
If your camera is a Leica Digilux 1, then the cards it can take are: Secure Digital Card and Multi Media Card
http://en.wikipedia.org/wiki/Leica_Digilux_1
If you have an earlier camera, then it could take some other kind such as the Compact Flash Card, although I did not find such a note anywhere.
Jul 10, 2011 | Leica Cameras
I received a Leica Digilux 2 from a relative and i cant seem to see anything thru the viewfinder or the lcd screen. Its just black. Is the shutter not open? I can see all the numbers and settings around...
Open the back of the camera. **** the camera as if you were advancing the film. While looking in the back, push the shutter release, like you were taking a photo.
You see the mirror flip up and glimpse a flash of light as the camera cycles.
If you do not see the mirror flip up and return, the camera needs serious repair..
As for the LED Display, put some new batteries in it.
Feb 12, 2011 | Leica Digilux 2 Digital Camera
When I turn on my Leica digilux-2, the monitor shows a photo from the SD card, but does not pick up anything else. The viewfinder is black.
Odd this has been here five months w/o a response. Apparently you describe a "burned out CCD", the famous "sensor problem", which is frequently mentioned whenever the Digilux 2 is being discussed. It's too bad because I think otherwise it is a wonderful camera. Contact Leica in whatever country you live and see what the current policy is re: repair, and whether the company will stand behind their product. There appears to have been positive response. Good luck.
Nov 10, 2010 | Leica Digilux 2 Digital Camera
Best make and largest size of sd card for the leica digilux 2
The Digilux 2 will work with any SD card, but bear in mind that SD cards max out at 2GB. Larger cards are actually SDHC cards and will not work in the Digilux 2.
Apr 18, 2010 | Leica Digilux 2 Digital Camera
New to digital bought a digilux 2 can you suggest a basic camera guide for digilux 2 thanks regards alf
Hello there,
Congratulations for your new Digiluc!
To start , u can get Digiluc 2 Guide here :
http://www.overgaard.dk/pdf/Digilux_Field_Guide.pdf
Install Media picture database software (u can use iPhoto for mac)
or get Microsoft® Expression® for PC (works on mac)
after that, you can set up the camera , for indoor set the lens to f/2 (not automatic).
go shot a lot now :)
hope this help a little :)
Apr 15, 2010 | Leica Digilux 2 Digital Camera
My Leica Digilux 2, recently purchased and never used before, doesn't appear to be taking pictures. It reads all memory cards (residule photos previously taken) however when taking a snapshot, the display...
Apr 13, 2010 | Leica Digilux 2 Digital Camera
Leica Digilux 2
The same problem, no idea how to fix it.
Oct 06, 2007 | Leica Digilux 2 Digital Camera
Digilux 2 problem
No solution- Humidity and moisture is death to Digital Cameras
Sep 28, 2007 | Leica Digilux 2 Digital Camera
No picture thru viewfinder or monitor
Okay, I have found the solution (along with Megant, it appears.) It is definitely a dead sensor issue. I contacted Leica via email (cs@leica-camera.com) and received a response from JoAnn Scott, a Leica customer service manager (joann.scott@leicacamerausa.com) stating that the sensor issue is a common one and is covered under an extended warranty. I shipped my Digilux 2 to this address:
Leica Camera Inc. / Customer Service Manager
Re: Dead Sensor Repair
1 Pearl Court, Unit A / Allendale, NJ 07401 / USA
and within 2 weeks received a repair ticket from Leica, identifying the issue and indicating a zero balance for the repair. A follow up with JoAnn revealed that the turnaround time on the repair would be 4 to 6 weeks. The most expensive part of this whole deal was the 18 dollars I spent insuring the camera when I sent it back via the USPS.
Hope this helps.
Feb 02, 2007 | Leica Digilux 2 Digital Camera
Leica Digilux 2 Digital Camera Logo
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
