Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
My engine surges,i tryed to adjust the gonvoner and now it just races and wont idle down
  • 62 Answers
Adjust the govenor back to where is was. You have a partially plugged carb
Posted on Sep 25, 2009
Can i take apart the lower part of my briggs and stratton to repair my govenor?
Are you saying that it surges at full throttle and wont idle down or shut off? If so it is likely not a governor problem. Surging is a lean condition. Some models, particularly yard machines, will surge no matter the adjustment unless under a load. If it were a governor issue it would run faster and faster beyond full throttle. IF it wont idle down check the throttle control and throttle linkage and check for a sticking throttle shaft before suspecting governor. Not shutting off could also be in the throttle control. A ground clip is in the control. if the tab is not engaging the clip or the wire is not connected then the motor will not ground. Check those things before messing with the governor, especially if the machine was running good and no one has messed with it yet. Governors don't just come out of adjustment by themselves.
Aug 31, 2014 | BRIGGS_AND_STRATTON...
1993 geo tracker idle up and down
HOT ENGINE? (ill guess hot)
idle surges.(hunts) (very simple reasons or very hard to find.
the car has 2 engines. G16A and G16B
they work totally opposite, (8valve and 16v)
the vin number tells you the engine type ,digit 8 is engine code
6= G16B 16v
U= G16A 8v
i have factory book. its in chapter 0 these facts.
the cause of idle surge and hunt are:
1: ISC failures. the ISC can stick partially open and then hunts.
clean it and test it . see videos of how.
2: engine running so bad the ISC can nOT regulate idle speeds.
#2 is caused by up to 50 reasons.
8v , air leaks, cause racing idle and iSC goes nuts.
16v , all air leaks cause lean and if too lean the ISC goes nuts.
by nuts , i mean it hunts or gives up.
the list is endless, but the tests are basic,
i cant help you because no engine stated.
http://www.fixkick.com/IDLE-AIR/idle-index-home.html
ISC = IDLES SPEED CONTROLER (a system not just a PART)
Jul 08, 2014 | 1993 Geo Tracker
97 toyota surges at an idle
(which engine. ?????)_
as always check all fuses. and scan the ECU for DTCs. first.
there is no need to fix OBD2 cars like 1980 cars (hard rows to hoe)
it can be 2 problems this......
lets fix the easy one first. idle. (and hope for moving issues to fix for free) it idle car is parked, so is 100% safe tests. (not moving)
so it surges at idle.
questions.?
1: hot or cold or both.?
2: low extreme RPM and high at idle.
400 to 800 RPM? surge.
1000 to 2000. what? numbers tell the tale.
first off, idle is the last thing to work right on any engine.
there are many ways to find what is wrong.
fix idle surge way.
i make sure that the engine holds closed LOOP status.
hot idle, if not , i fix that first.
keep in mind if not in closes loop and lean
all lean engine surge and guess what the ISC will add to the surge
because idle is way too slow, so the ECU open the ISC wider
and wider and its still too slow, so the ECU resets the ISC
this cause a worst hunt (surge)
the ECU adjust spark time and the ISC to get 800 rpm. (spec. look up yours)
so say , i see closed loop failed, OBD2 scan page 1
i look at the O2 sensor an its stuck lean.
if stuck lean and it really is (o2 bad?) then its lean and it will surge
examples.
1: i find 02 sensor bad, (only effects idle and light steady cruise)
2: i find fuel pressure at 15PSI , hopeless low .
3: i find all injectors clogged. and lean.
4: with MAF EFI, ( i find maf reading too low, (dirty) causing lean.
5: if MAP car, i find the MAP stuck hard high vacuum causing lean.
not knowing what engine you have or the idle hot surge range,
i can not go farther.
the driving bog tells me,
1: scan the ecu ,get DTCs; do that first.
2: clean MAF if car has one, ask how..
3: check fuel pressure.
my guess is engine is lean. and starving for fuel all the time.
cept WOT.
MAF cars starve for fuel if there are any vacuum leaks.
MAP cars do opposite, they race fast with 100% full power.
MAF is air density EFI
MAP is speed density EFI.
apples and oranges diffr. so what engine.
Jan 07, 2014 | 1997 Toyota Tacoma
How to adjust idle?
hot engine ?, cold or both,, EFI runs in 3 modes, cold ,warm and hot.
name it.
which engine option (displacement)??????
there is no idle adjust, that is the PCMs, job 100%, all the time.
Carbs are gone.
here is rule one for all EFI.
idle is the last thing to work correctly.
anything the causes a gross imbalance of engine power to engine load, under idle will cause , idle controls to fail.
low idling causes. (over 50 but, here ar basics)
1: AFR (air fuel mixture too lean) usually surges. (clogged or leaking injectors. or fuel pressure way to high)
2: air leaks, cause racing, so not that. (speed density car ,if is)
3: egr stuck open. low idle and misfire.
4: ISC stuck closed (IAC electric)
5: cam belt slipped, timing retarded, compression at 1/2 spec, and well, valve will bend soon....
6: CEL glowing running? can be in limphome, limp cancels Idle controls (in may cases) RTM read the FSM on DTCs.
if fails hot?, is hot = 180F temp or more? "thermometer time"
if not, the PCM goes , quite nuts.
Dec 23, 2013 | 2010 Honda Civic LX
1990 geo metro engine surges up and down when stopped..... prevous owner told me he turned the idle down. So, is the surging a direct result of idle adjustment or something else? ...and where is the idle...
hi sounds like your engine is surging due to incorrect mixture now your idle screw is on the thottle cable were it connects to the carb and the mixture screw is on the carb body as an approx guide turn the mixture screw fully in then out two and a half turns that should help but y may need to fine ajust later
Nov 15, 2009 | 1990 Geo Metro
Engine speed surges
Surging engines in lawn mowers are usually related to a lean fuel/air mixture. With today's environmental concerns, the carburetors on these engines are set with a very lean mixture (to reduce air pollution). Furthermore, they usually put limiter caps on the carburetors where you cannot easily adjust the mix to get the engine to run better.
If there are adjustment screws on the carburetor, try turning the high speed adjustment screw a bit counter-clockwise (if the limiter cap will allow it). This will enrich the fuel/air mix a bit and might help the engine run a bit better.
Oct 11, 2009 | Garden
Engine starts,reaches high rpm,then slowly returns to a rough idle, misses badly,no backfire,surges as if searching/adjusting air/ fuel/est,timing light shows mark constantly changing/erratic,engine then...
Vacuum leaks. Check all hoses and intake bolts. Leaking EGR or plugged PCV valve. Air filter plugged. Leaking head gasket. Worn timing chain. Camshaft lobes worn. Valves burned or leaking. Fuel idle control system or sensor. Good luck!
Apr 18, 2009 | 1991 Chevrolet Camaro
Rough idle / engine surges until power is applied
Sounds like a possible vaccume hose leak?
Feb 07, 2009 | 1997 Chevrolet Astro
1990 Toyota Celica GTS. Idle races too high
sound very much like a vacuum leak.... also maybe your timing is off? possibly advanced? try retarding it with the distributor if thats the case...
Jan 01, 2009 | 1990 Toyota Celica
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
843 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
