Question about Casio FX-300MS Calculator
Need to know how to do squre roots step-by-step
  • 53 Answers
Type 2nd then the square root sign and type in the number u need. the close off the parenthesis and hit enter
Posted on Sep 29, 2009
  • 46 Answers
Check out this web site, http://www.mathsisfun.com/square-root.html
You can also use the google calculator function. go to google if you want the square root of 5 type: square root 5=
and google will solve it. for use with a calculator the other poster is right, enter the number ie:5 then use the x2 button or sqrt button.
Posted on Oct 05, 2009
How can i root my htc amaze 4g smartphone?
search for super backup from play store it will help to backup all contacts, apps,SMS etc. after that move all data from internal storage (becausethis gonna erase all data) on PC or SD card.
after that u can proceed for unlock bootloader and go for root ( search On Google how to root very easy steps to do.) If u can't able to root let me know I will explain step by step. Enjoy ;)
Jul 19, 2014 | HTC Amaze 4G Smartphone T-Mobile
Tip
How to fix Blank Device manager
RESOLUTION:
CREATE A RESTORE POINT BEFORE ANY OF THESE STEPS
STEP 1:
Check if Plug and Play service is started.Check the settings of the same in the
registry
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PlugPlay
ImagePath = %SystemRoot%\system32\services.exe
ObjectName = LocalSystem
PlugPlayServiceType = 3
Start = 2
Type = 20
STEP 2:
Advanced cleanboot (316434) and Hardware cleanboot (SOX051008700004)
STEP 3:
System restore (306084)
If we know when the issue started, read the system restore point information for
that day prior to trying the restore
STEP 4:
Look for the update KB905749 and try uninstalling it. Be sure to shut the system
down and wait 10 seconds before restarting.
STEP 5:
Go to safe mode - check for bangs in hidden devices in System devices - Uninstall
PnP BIOS Extension and any other device having a bang
STEP 6:
- Follow SOX041029700032
check the permissions on
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASAUTO
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASAUTO\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASAUTO\0000\Control
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASMAN
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASMAN\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASMAN\0000\Control
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_TAPISRV
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_TAPISRV\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_TAPISRV\0000\Control
If Administrators is listed, then remove Administrators. The default permissions
for these keys are:
System : Full Control : This key and subkeys
Everyone : Read Only : This key and subkeys
Change the permissions so that they apply to "This key and subkeys" and not just
"This key only".
STEP 7:
We could try to register the following files
regsvr32 devmgr.dll
regsvr32 dmocx.dll
If the files are missing, extract a copy from Windows XP CD-ROM or the
ServicePackFiles folder
STEP 8:
Copy the following on a notepad.Save it as dev.reg.Double click on the same.Restart
the computer.
on May 03, 2010 | Computers & Internet
SQURE ROOT 126 TO THE POWER OF TWO
The square root and raising to the second power cancel each other so the result is 126.
Apr 18, 2013 | Office Equipment & Supplies
4 squre root 81
Take the fourth root. The square root, denoted by a 2 on top of the "root thing" or more commonly without a number at all, is the second root.
Usually the easiest way to calculate the fourth root is to calculate the square root of the square root. So in this case the fourth root of 81 is the square root of the square root of 81. The square root of 81 is 9, the square root of 9 is 3.
Have a Samsung galaxy tab 2 , 7.0" ...3113 .....4.1.1 want to root need to know what to down load to my pc and how to due it..thanks
Step 1:
1. The following procedure works for Samsung Galaxy Tab 2 P3113 smartphones.
2. Make sure your device have at least 80% battery power.
3. Make sure USB Debugging is enabled
Step 2:
1. CF-Auto-Root to root P3113UECLK7 firmware [Filename: CF-Auto-Root-espressowifi-espressowifiue-gtp3113.zip]
2. Odin 3.07 [Filename: Odin307.zip]
Step 3:
1. Extract Firmware zip file and you will get a .tar file and some other files.
2. Extract Odin zip file and you will get Odin3 v3.07.exe along with few other files.
3. Switch off your Galaxy Tab 2 P3113
4. Now, put the Galaxy Tab 2 P3113 in Download Mode by pressing and holding the Volume Down key and Power button.
5. Then, a warning message appears, press the Volume Up key to continue.
6. Now run Odin3 v3.07.exe as an Administrator because Admin privileges is required to complete the process smoothly.
7. Now connect your Galaxy Tab 2 P3113 with your PC using USB cable.
8. Then a message will arrive under Odin's message box in the bottom left saying "Added!!"
9. Select these files in Odin at respective tabs from extracted firmware folder:
  • Click the PDA Button, and select the CF-Auto-Root-espressowifi-espressowifiue-gtp3113.tar.md5 file.
10. In Odin window, make sure Auto Reboot and F. Reset Time checkboxes are selected. Also, make sure that Re-Partition checkbox is selected, only if you are using a .pit file.
11. Double check everything that we mentioned in Step 9 & Step 10 above. Now, once satisfied hit the START button to begin the flashing process.
12. Once flashing completed, you will see a PASS message with green background in the left-most box at the very top of the Odin. The tablet will then automatically rebooted and soon you will see the Samsung logo. You can then unplug the USB cable to disconnect your device from computer.
Congrats! Your Samsung Galaxy Tab 2 P3113 running P3113UECLK7 Android 4.1.1 Jelly Bean firmware is now rooted. You can now install apps that require root permission.
Apr 05, 2013 | Cell Phones
Download root
Only root your phone if u know it. Rooting may also terminate your phone's warranty.
For detailed steps for rooting your galaxy ace phone visit this link
http://www.androidauthority.com/how-to-root-your-samsung-galaxy-ace-37385/
Jun 04, 2012 | Android Galaxy Ace
I want to up root a coby kyros mid 7015
Rooting your phone and installing your own custom ROMs available online gives a new lease of life even to the first generation of Android Phones.
Here is a step by step rooting guide.
Mar 10, 2011 | Coby Kyros 716829701508 Tablet PC
Geometry-
this is a math problem?
the area of the old square was 100, the new one is 225
say the old squares side was X, so the area was X^2
the new square has area 2.25 X^2
take the square root to find the side of the new square: 1.5 X
so we know that the side of the old square plus 5cm is the side of the new square. so X + 5 = 1.5 X
solve that to find X = 10,
so the area of the old square was X ^ 2 = 100
and the area of the new square is 2.25 X ^ 2 = 225 :)
Aug 10, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Casio FX-300MS Calculator Logo
288 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
