Question about Kitchen Appliances - Others
Opal 2 trips when 2nd heat button is pressed??
9.5kw -opal 2 trips when 2nd heat button is pressed?? cold water & 1st heat button are ok
    President:
  • 1,714 Answers
The second button brings on another element for more heat , it is a bad element and trips the breaker. The second element needs to be replaced. OR...don't hit the second button...
Posted on Sep 26, 2009
Testimonial: "thanx 4 the advice on my opal 2. Now i know what i'm lookin at pricewise, cheers..:-)"
I have a 21b20m 20kw electric furnace when weather is cold the 100 amp breaker trips two or three times a day can you help please
If you have a heat pump you usually have 1st & 2nd stage emergency heat . Your 2nd set of elements may be bad. You can test this with a meter by ohming across each element and it should read a ohm value. Then ohm from the element to ground and it should read OL if it does not it is shorted. Also 100 amp breakers for some reason always fail I have changed more 100 a breakers than any other size. You can also get an amp probe and turn your thermostat up and read the amp draw to see if it is close to 100a. Hope this helps
Dec 26, 2013 | Electrical Supplies
How do you print 2 lines?
Go to INSERT button (2nd from left) press button then use arrows to find "second line". Then press OK and screen will indicate 1st and 2nd lines.
Aug 03, 2011 | Dymo LetraTAG Thermal Label Printer
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
How does one 'colour test' please.
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink button on the control panel and select CLEANING press OK.
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Apr 03, 2011 | Brother MFC 490cw Color Inkjet...
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
When I put the disc in to be copies and then the blank discs i press the green start button and it display target drive not ready. How do I get it to copy onto the other discs??
One of the "target" CD-writers is not working -- either the "data" cable is not connected, or the "power" cable is not connected, or the drive itself (either the "spinning" motor, or the "laser") has failed.
Presumably, you don't have to fill "all" the trays, in case you only want to make a few copies of the "source" disk.
So, make a few attempts, with the "source" disk in the "source" drive:
1. put a blank disk into the 1st "target" drive,
leaving the other targets "empty", and press the button.
If it works, then the 1st target drive is OK.
2. put blank disks into the 1st and 2nd "target" drives,
If it works, then the 1st and the 2nd target drives are OK.
3. put blank disks into the 1st and 2nd and 3rd "target" drives,
If it works, then the 1st and the 2nd and 3rd target drives are OK.
... and so on
If you get a "failure", then you now know which of the "target" drives is the "bad" drive. Either replace that bad drive, or change the cabling inside the unit to "bypass" that bad drive, and put a sticky-label on the face-plate of that drive, saying "do not use this tray".
Oct 16, 2010 | MicroBoards Quick Disc QD-123 (QD-123)...
I have a intertherm when it cold do i put it on
Leave it on heat all the time. If the 1st. stage heat fails and the room temperature drops approximately 2° or 3° F then 2nd. stage or emergency heat will kick in. If you have a heat pump when it goes into defrost it will kick in the 2nd. stage heat.
2nd. stage heat will maintain at 2° or 3° lower than your thermostat setting.
Dec 30, 2009 | Heating & Cooling
1992 tracker automatic transmission shifting
I have the same problem also. Hope someone has the answer.
Oct 07, 2008 | 1992 Geo Tracker
Kitchen Appliances - Others Logo
59 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
