Question about HP OfficeJet 6210 All-In-One InkJet Printer
There is a jam in the feed for the fax. - HP OfficeJet 6210 All-In-One InkJet Printer
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper jams continue to occur on brother fax 2820
Depends on the location of the jam is. Feed wheels need cleaning, clean with windex. or and most likely you have a bad drum unit,
Jul 28, 2008 | Brother IntelliFax-2820 Laser Fax
Paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
May 03, 2008 | Brother IntelliFax-2820 Laser Fax
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
Paper jams when trying to send fax (original goes in short way then jams) unit has had little use it establishes connection and then stops and jams when commencing scan
look in paper path(scanner compartment were paper feeds) to ensure there is no pieces of small paper or foriegn items in this area preventing paper from going all the way through if this fails clean the feed roller in document scan area with a micrfiber cloth moistened with rubbing alcohol
Jan 13, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper jam
There is either a jam in there somewhere where you can't see it, or if it clears, the feed roller is not feeding the paper, in either case you probably need a tech.
Jan 07, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Paper feed jam
it will give you a break if the tires are not worn out. Look and feel if they are smooth, if they are smooth and shiny then replace otherwise clean with alcohol.
good luck
Dec 12, 2006 | HP 1010 Plain Paper Thermal Fax
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
HP OfficeJet 6210 All-In-One InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
