Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Freezer door won't open
We've moved and I wonder if the movers may have tipped or dropped our Maytag french-door fridge. We cannot open the freezer! Not sure how the racks could be jamming the door, if that's the problem. Is there a lock on the door the the movers might have engaged?
It is super tight! there must be a lock! i feel like i am going to break by the amount of force i have been prying it open! but i still cant get it do so. right now i disconnected it to defrost
Posted on Nov 04, 2011
    Problem Solver:
  • 9 Answers
There is no lock. More than likely the Door is off track and needs to be reset or ice has set up in the track ceaseing the rails up. In any case this isn't easy you need to get your bottommount freezer door pulled open you may have to use some force and be very careful not to brake it there is alot of plastic. Once you get the door completely out of freezer unclip the rails from the plastice rails and reset the two gears (evenly) to make door shut right. Push metal rails all the way back to you hear a click. Then reverse steps to install freezer door.
Posted on Jan 20, 2008
How to replace the light bulb in the Maytag french door bottom freezer
Hopefully you have figured this out. Its fairly simple to do. If your freezer if full you will need to empty enough that you can place your hand in and on the Plastic Light cover. Its in the center at the top of the freezer. This cover is removed by simply applying a little pressure to the right and left corner and pulling toward you and down. The light cover with very little pressure should mover and pull down. Once it begins to lower in the back just keep a hold of it and mover your hand toward the rear of the freezer and the front tabs will slide out.
After changing the light bulb, simply put the front two tabs of the front of the cover in first and snap back into place by pushing up. Takes about 3 minutes to change the light bulb. Good Luck!
Dec 24, 2012 | Maytag MFD2560HES Bottom Freezer French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator won't cool but the bottom freezer works
under bottom shelf there are air inlets to fridge take out tray clean ice frominlets
Jul 22, 2012 | Maytag MFD2560HES Bottom Freezer French...
Fridge won't cool. Freezer is still working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Maytag MFD2560HES Bottom Freezer French...
Freezer works, fridge doesnt!
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 26, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Fridge not cooling freezer top mount ok
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
88dt
Apr 27, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
439 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
