Question about Coby MP-C7085 MP3 Player
My mp3 only play one song and the screen is messed up so i dont no how to get to other ones
Dont wana play song
Erase all the songs you placed on the MP3. Place one song and see if it plays it. If it does, then you have one bad song that is causing the MP3 to malfunction. You will need to check each song to make sure it is not corrupt before placing on the MP3 player. To do this, just open with Media player and see if it plays.
Apr 02, 2010 | Audio Players & Recorders
No sound
Ok, the problem is you need to convert the songs that don't play into mp3 files unprotected mp3 files then they will play.
Jul 09, 2008 | iLO (2 GB) MP3 Player
I have a Slick 2gb mp3 player all songs don't sync get error mess
i don't know but i have one and i recommend you just copy and paste them to the folder because if u sync it will be in different folders on the mp3 and if u listen using random it will only play the songs in the folder you are in .
Dec 29, 2009 | Audio Players & Recorders
My song titles are messed up in my Samsung YP-Q1 MP3 player!!
Plug in your MP3 player to your computer. Open
the player list. Locate the songs you want to change and right click on the song. One of the options listed should be "rename". Simply type in the name you wish and left click in any blank area on the screen.
Aug 20, 2009 | Audio Players & Recorders
Having problem syncrinizing music to mp3 player
if u used window media player its will mess up your mp3 by duplicating songs and not leting u play songs. What i do is connect it to the computer and it should pop up. DONT open window media player. Open the files and add your music by dragging them into your mp3 from another folder. This only works if you have a different folder of music. It should work. If all your music is in Widows media player it wont work. Also try deleting all your music from ur mp3 but copy your musice onto your computer first. Good luck i hope i helped.
Apr 08, 2009 | Philips GOGEAR SA6045 MP3 Player
Downloaded songs but won't play on go gear 3020/37 how do i fix
First try opening the gogear device and click on music right after the welcome screen. Select either "All Songs", "Artists" or "Albums" to find your songs. If you downloaded your songs, they should display on the screen of philips gogear, then you can select them to play on your headphones
Only some audio formats (.mp3 .wav and .wma will be play on philips gogear SA 3020/37)
Feb 23, 2009 | Philips GoGear SA3020/37 MP3 Player
It Wont Read The songs
The songs are in the wrong format - it does not recognize iTunes songs or DRM-encrypted songs which do not have "transfer rights" (many msuic services - especially free ones but also paid ones - give you WMA's that have "play rights" -i.e. you can play them on your computer; but if they do not have transfer rights, they will show up in your player, yet not play correctly/skip).
Transfer only songs that are in Mp3 Format and you will never have this problem.
-Tha Mp3 Doctor
Dec 24, 2008 | RCA TH1101 MP3 Player
Screen not showing and can't tell what I am doing.
Also, here is alink to the user manual that will show you exactly how to change away from repeat and back to shuffle:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Apr 30, 2008 | SanDisk Sansa Clip MP3 Player
"invisible" songs
You might have to reformat your MP3 player. First make sure you have a good backup of your songs. Then reformat the memory card or memory on the H116 MP3 player and re-copy the songs back to it.
Mike
Nov 21, 2007 | RCA H116 MP3 Player
Coby MP-C7085 MP3 Player Logo
15 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
