Question about Microsoft Xbox 360 Console
Drive bay won't open Power lights flas.
Drive bay won't open. Power lights flash.
  • 767 Answers
It's the Hub magnet clamping down on the spindle .
After time the motor gets a little weaker and has trouble
breaking the magnetic seal ,in order to release the laser
carage so it can drop down allowing the trey to open.
If you press eject wait 1 sec then slap the top
of the C.D drive area FIRMLY don't worry this will
no harm the unit. The tray will open up
The temp fix is to put vaslien in the guides under the
Gray tray , and a little rubbing on the black belt located
to the right under the drive tray Just in side front of
the C.D. drive. then work it in opening and closing
the drive repeatedly.
If you have any questions just comment and ill respond.
Rob
Posted on Oct 24, 2009
  • 54 Answers
Hey is it a "tapper"
with xbox original the drive rubber band would stretch
so you can either tap the top and the drive should open and give it a nice knuckle kinda strong but dont freaken mike tyson the console
or if your daring open the 360 (voids warranty)
and take out the little rubber band boil some water and throw the band in the water the band will bubble for a couple sec
take it out of the water and place back in the origanal fasion walla fixya bain badda bing
Posted on Oct 19, 2009
    President:
  • 4,402 Answers
Http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
Posted on Sep 25, 2009
Tip
Laptop Battery Won?t Charge?
If your dell laptop computer runs normally on the AC adapter, but the battery won’t charge, please try the following troubleshooting steps:
Check the dell laptop battery and Connections:
1, Remove the battery from the system.
2, Look at the connectors in the bay and on the battery for signs of physical damage.
3, Check the battery charge by pressing the status button or image on the battery near the LED’s.
Note: The lights indicate the current amount of charge on the battery. If all the LED’s come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
4, Reinsert the battery; push until it locks into place and the latch snaps back to the locked position.
Swap Bays or Try A Second Computer:
1, Some systems can run with the battery in either bay. Try swapping bays if you have one of these systems.
The following systems permit a battery to be used in either bay:
Inspiron systems 3700 3800 7500 4000 4100 4150 8000 8100 8200 Latitude systems CPx H CPt V CPx / CPt C600 C610 C640 C800 C810 C840 Note: It may be necessary to slide the face plate left or right on some batteries when switching bays. 2, If you have access to a second computer like your own, try to charge your battery in that system.
Flash the BIOS:
Flashing the BIOS can correct many hardware issues.
NOTE:Dell recommends that you update the BIOS on your system, only if you are having problems
1, Go to “The Dell support site”
2, Be sure your system is the one listed in the Your System section on the left.
3, Click the Downloads tab
4, Choose your operating system from the drop down menu
5, Select FlashBIOS Updates as the download category.
6, Click Go.
Select the link to download the most current version of the BIOS:
1, Save the program to your desktop.
2, Go to the desktop and double click the icon.
3, You will be given the option to either create a BIOS disk or flash the disk from the hard drive.
Run the Recalibration Utility if Your System has One:
This utility runs the battery all the way down and then recharges it completely. The process takes several hours so it is best to run it overnight. Use only the recalibration program specified for your system. Using any other program could void your warranty!
Latitude LM, Inspiron 3000 and Inspiron 3200 systems use this recalibration program: BATRECAL.EXE
Inspiron 5000, Inspiron 7000, and Inspiron 7500 systems use this program: I75BRCA0.EXE
Latitude LS, Latitude L400, Latitude X200, and Inspiron 2100 enable a recalibration option on the Power page of the BIOS Setup Program:
How to Enable Battery Recalibration
Try to charge a second battery like your own if possible.
If the second battery won’t charge, the problem may be caused by the charging system in your computer.
If the battery still won’t charge after you have done this troubleshooting,it mean you should replace your old battery,you can go to www.sales-battery.com to choice a new dell laptop battery replacement
post via:dell.com
Battery purchase information:
US shop
http://www.sales-battery.com/laptop-batteries/dell.htm
UK shop
http://www.global-battery.co.uk/laptop-batteries.htm
need Universal External laptop battery
http://www.global-battery.co.uk/universal-external-laptop-battery.html
http://sales-battery.com/External_laptop_battery.html
on Jun 15, 2010 | Computers & Internet
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
My flas disk capacity not show in pc. It can't open
i think it is due to your fash drive hardware failure. try to right click on your drive and select format. if format compelete successfully then drive is ok but your system is infected with viruse which denied accessing your pen drive. better thing is use windows explorer and click your flash drive check whether it open or not.
Jun 28, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Flash drive write protect. How do I remove the write protect?
small sd cards have a small slider in the care itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
Sep 12, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
E: Access Denied when I connected a Flas Drive on a HP DC 5000
if you contact the manufacturer of the flash drive they may have a reset program for it.. I had a similar problem with a flash drive that I had configred as a key to lock my pc.. but I forgot the password and the flashdrive was then worthless even the reset prog couildn't help it :( hate to be the devils advocate but you may have to replace the flassh drive
May 18, 2009 | Computers & Internet
How do i put pictures on this flas drive
Plug the flash drive in the USB 2.0 socket on the computer
Open my computer
You will find a removable drive next to your cd/dvd drive
Open it and you can copy and paste your data or pictures on it.
Jun 08, 2008 | Computers & Internet
Flas drive
it is attacked by a virus or a trojan,,,try to scan it with a good antivirus program
Jan 01, 2008 | Electronics - Others
Nikon SB-800 Defect
Have you tried other batteries?
If one cell has died, there will be enough power to power up the flash, but not enough to charge it reasonably fast. It may also stop the other cells charging up properly if they are charged together. I've had this problem with poor quality rechargeables before. I think flashguns put pretty heavy demands on batteries.
Oct 23, 2007 | Nikon Speedlight SB-800 TTL Flash
My c600 is not puttin power in battery
if its the battery with a press button that lights up 5 green lights.. if u hold it for about 6 seconds it should light up all or some in a row like 000.. ( depends on charge it has) after 6 seconds none should flash , they should turn off . if any do flash or led green are missing in between its likely a bad battery.
Sep 29, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Microsoft Xbox 360 Console Logo
174 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
