Question about Dell Inspiron 1525 Notebook
No internal disk drive was found - Dell Inspiron 1525 Notebook
  • 59 Answers
Sounds as tho your hard drive has gone bad. Try re-seating the hard drive in the laptop while it is off and then re-booting. If still nothing, goto a local pc store with your old drive and ask if they have a used one around 20-40 gig for real cheap, under 20$ and test it, or ask them if they could just test with a different drive.
Posted on Sep 25, 2009
    Novelist:
  • 137 Answers
Turn off the computer and then press and hold the Fn key and then turn on the computer, keep holding the Fn key down untill you see diagnostic boot selected. then you can release the Fn key. it will do the test on the machine. hardware test and then if you get a rainbow press Y to continue. then after few minutes you might get an error code.
Click here to get the list of error codes. and in 0141,0142,0143,0144,0145,0146. hard drive needs to be replaced.
Posted on Sep 26, 2009
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
When i open my acer 4047 just displyd for setup key f2/f12 to pres,then i press f12 to reinstall new windows but there is i dont fine any hard drive?
Seeing as this is an approximately 8-year-old laptop, if you are getting a message that no hard drive is found, you have one of two issues.
Either your BIOS has reset itself and is not looking at your internal hard disk as the boot source and the message is not hard drive not found but boot disk not found .... OR ..... your hard drive has suffered a failure and needs replacement.
Jan 14, 2012 | Sony VAIO PCG-K25 Notebook
I have reseated the hard drive in my inspiron 1525 laptop and it still says internal hard disk drive not found. what can i do?
You might need to borrow another hard disk drive from your friend or relatives and try it on your laptop. If it still does not work, then we can assume that the laptop needs repair with the hard disk drive port.
Hope this helps in resolving the issue...
Sep 12, 2011 | Dell Inspiron 1525 Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Says internal hard disk drive not found, to resolve this issue, try to reseat the drive
The hard disk has died, you will have to replace it with a new one then reinstall Windows using the recovery disk.
Dec 10, 2010 | Dell Inspiron 1525 Notebook
What is the max hdd capacity I can install in a HP ZD8000 laptop?
Your computer uses ATA drives which topped out around 250MB simply because manufactures switched over to SATA drives. It is a pain to change out disks on laptops since you can only have one internal drive. You then have to reload everything.
Here is one I found: Western Digital Scorpio Blue WD2500BEVE 250GB 5400 RPM 2.5" ATA-6 Internal Notebook Hard Drive -Bare Drive
  • 250GB
  • 5400 RPM 8MB Cache
  • ATA-6
I'd consider one of the external USB disks instead to store your data, pictures, etc. You could then put it on your desktop or on a new notebook.
Sep 16, 2010 | HP Pavilion zd8000 Notebook
My external hard drive is 300g,i formatted my internal hard drive and found that my external drive was also formatted and was only 3g.could someone help me please that's a lot of space lost
do you have a recovery disk for the internal hard drive? this is the disk that came with pc.your internal HD is important this have been wiped (you have no OS) . get your internal back in order........do you have a receipt that says you purchased a 300gb (not 3gb) take it back get your money or the right external... once you are able to use the pc double check the external hard drive
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
Hoow do you open gateway MX6440. No audio. Bootup
Typically, a computer tries to "boot" from several devices:
1. 3.5-inch diskette
2. internal CD-ROM
3. internal disk-drive
4. USB memory-stick
5. network (if a "boot-server" can be found on the network)
6. external diskette
7. external CD-ROM
8. external disk-drive
So, in your case, either
* the "boot-order" _EXCLUDES_ your disk-drive,
* your disk-drive is not connected,
* your disk-drive is connected, but is "dead" (not responding)
Not being able to boot from the disk-drive, your computer probes, via the network, for a "boot-server". Finding none, your computer reports, in a strange way, that "network cable is not connected to a boot-server".
So, the "check cable" means that the Ethernet cable between the network-port on your computer and the boot-server may be "unconnected".
What this could mean is that your disk-drive is "dead".
Take the computer to a qualified technician, for more trouble-shooting.
Nov 18, 2009 | Gateway MX6440 (6585) PC Notebook
Internal hard disk drive not found
This is due a hard disk failure or setting changed on your bios. Insert the Win CD and check the status of your disk or use some utiluty program to check the hard drive.
Feb 03, 2009 | Dell Inspiron 1521 Notebook
External Drive not recognized
Have you tried in Disk Management Right-Clicking on the drive and selecting 'Change Drive Letter and Paths...' ? That is the normal way to change or add a drive letter to any drive, internally or externally attached (other than by network connection)?
Dec 03, 2007 | Western Digital My Book Essential Edition...
Dell Inspiron 1525 Notebook Logo
291 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
