Cleans after every copy
When I send a document to the printer the printer goes into a cleaning cycle and stops printing if there are multiple copies of the same document.
  • 3 Answers
SOURCE: hp business inkjet 2800
Sounds like your driver is sending A4 size documents, and you've got Letter in the drawer. When you do that, it runs out of room on the Letter-size page, since A4 is a tad longer, and has to continue onto a second page. Margins being what they are, the second page is usually blank.
Hope that helps.
Posted on Jul 31, 2008
freetek
  • 5568 Answers
SOURCE: My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Posted on Sep 23, 2008
  • 214 Answers
SOURCE: Brother MFC 440Cn will not print multiple copies
Gotta be a software SETTING for page count
Posted on Apr 23, 2009
SOURCE: My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Posted on Mar 01, 2010
  • 8 Answers
SOURCE: Problem printing multiple copies of a single page document
I have a similar problem with an old HP LJ1300. They have not updated the driver correctly and don't intend to fix it. I can't find any reference to AcuLaser C900 on Epson's support page. So maybe they stopped supporting the C900.
Posted on May 07, 2010
My HP printer is printing multiple copies of the same document every time I print. The only way to stop it is to cancel the printing job.
it sounds like in your printer driver, the number of copies is set to more than 1 page.
go to printer drivers, and look under printing preferences, and look for what themultiple copies are set to.
Aug 30, 2010 | HP Office Equipment & Supplies
Duplicate print below each line on copies/printing/fax, changed fuser unit and drum unit and had cleaned. Seems to happen after toner changes, can the toner cartridge holder be defective and cause this...
Try to stop the copier (by jamming a sensor or opening a cover) mid-way through the printing cycle. Remove the 1/2 copied document out from the drum area. Look to see if you have the double printing. This will eliminate the fuser as the problem. If you don't have the double printing then the fuser's cleaning roller may be shot causing repeat image. If it is in the drum area it will be hard to determine since you already replaced the drum(?). But there is a "cleaning" lamp or charge wire on the drum to check.
Aug 10, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
MULTIPLE FEED PROBLEM
There is a little with pad that is called the seperation pad. You can see this under the pick up rollers. Clean this off with some alchohol. It may fix the problem. If not a new pad is needed.
Speration pad needs cleaned or replaced. Its a $10.00 part.
Jan 09, 2009 | Canon PC1061 Copier
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
jasbo
jasbo
