Question about Brother MFC3240 Multifunction InkJet Printer
MFC3240C says it cannot clean. No jams or foreign items in it. Unplugged several times, but still not changed. Recent upgrade to Mac OS 10.6-driver upgrade needed? Still faxes, won't print or copy.
    President:
  • 2,306 Answers
The unable to clean message means that the ink absorber is full so it can't take any more waste ink. It's a shop repair to replace the box and enter service mode to reset the counters.
Posted on Sep 25, 2009
How do i removing yahoo net safety from a mac
Download the App "AppCleaner.app"
Drag your Yahoo app to the "AppCleaner" icon
It will find all the associated files connected with the Yahoo item. Then just delete.
But.... Your machine looks like it might be in need of a full update?
Use this tool to see if your Mac can handle a Newer OS X.
Mactracker
This will give you all the tech info on your Mac
If Maverics is acceptable and you have say 2gb of RAM!
Then, Download the free Maverics OS X first.
Prepare an external USB Hard Drive (or Partition)
Try doing a full Clone Backup with CCC to the External HD
When finished Prove that the Clone is Bootable.
Use Option Key on Reboot. If OK
Use Drive Utility to Erase Internal HD ready for a clean install.
Then install a new clean OSX10.8 (Maverics) to get your machine almost up to the latest with a cleaned up pristine Mac HD.
Use Migration Assistant to return only the data files you want or just drag the "User" folder across by hand.
(Migration will bring back the Yahoo Software)
Mac Backup Software
OS Mavericks 10 9 Download
Sep 01, 2014 | Apple Leopard 10.5 Osx Mac Operating...
I HAVE AN APPLE POWERBOOK G4 I PURCHASE FROM EBAY IT IS CURRENTLY RUNNING MAC OS 9 ,HOW CAN I UPGRADE TO OSX 10 ?
Hi Bobby
You will need to get an OS X installation DVD. Try eBay.Don't go for anything lower than 10.4 (Tiger)10.5 (Leopard) and 10.6 (Snow Leopard) should run fine on this machine.Don't bother with 10.7 or 10.8
Jan 05, 2013 | Apple PowerBook G4 Mac Notebook
Mac freezes up no particular time, thought it might be just in Mail but no it has happened a various occastions...I have the 4000 nvidia for mac- mac pro 12 cores-24 gig of memory.-..help
I don't have this card but I am very interested in buying it so I have been tracking reviews and so far I have heard a lot of problems with this card. Some things to check. What version of OS X are you running? I have heard many complaints about the card's performance after upgrading to OS X 6.6. If you have 6.6 you should reinstall the drivers and sometimes that helps. I would go to both apple.com and nvidia.com to make sure you have the best and most recent drivers. Good luck.
Jan 25, 2011 | PNY NVIDIA Quadro 4000 for Mac Video Card
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
I upgraded my computer from Mac OS 9.1 to Mac OS 10.5 and now my computer doesn't recognize my hard drive
Try to unplugged power cord from main power source and open the case of your desk top computer. Stretch out some cable that connects to your hard drive. After that connect all necessssary connections for a self test. When you switch on, touch "del" several times to open a CMOS set up wizard. Look if your hard disk is recognized by the computer. If you can see the specified model of your HDD in the CMOS then you press F10 or just press ESC to reboot.
Jun 21, 2009 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
I did something to the OS on my iMac 9.1 and now it wont wont start up or boot.
do you have the original disk, you can reinstall the software.
or you can do an upgrade to a more recent version of mac OS like 10.5
will your mac handle the upgrade?
give me some specs i will find something you can upgrade to.
might as well
Jun 07, 2009 | Apple iMac OS 9.1
Scanner problems after Mac Leopard Upgrade
check this link then make sure that you can send a 10 megabyte zip file to that folder from a regular pc with permissions and you can open it without corruption from the mac... if you cann't then you have network problems
Jan 06, 2009 | Kyocera Mita KM-2530 Laser Printer
Paper jam
Make sure you don't have too much paper inserted, make sure its a little loose, if you push it too thighly it wont come out correctly.
Let me get you instructions for clearing that jam in a moment.
Oct 28, 2008 | HP LaserJet 1200 Printer
98 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
